Page 2 of 2
why does my x5 have no amp
Posted: Sun Nov 06, 2011 8:39 pm
by jeegnesh
[quote=""shadrack""]ive tried that with one of them conectors thats phono connectors tp 5 wires left +, left-, right+,right - and ground and all i get is a drone from the sub? its a vibe 1 channel amp so realy simple, what i did worked on my old x5 but i had to do it behind the headunit, this one tho has the nav screen?? im confuddled[/quote]
are you sure that you spliced into the rear speakers? You should not use the front speaker outputs. Also that you definetly got the right and left all correct. You got the colours for the wires you used, may jog my memory.
And yes you can't do anything behind the nav screen because it's just a dumb screen all the brains is in the back.
Posted: Sun Nov 06, 2011 8:43 pm
by jeegnesh
Found it.
Rear Left
+Yellow w/ Violet Stripe
- Yellow w/ Grey Stripe
Rear Right
+ Blue w/ Violet Stripe
- Blue w/ Grey Stripe
Re: why does my x5 have no amp
Posted: Sun Nov 06, 2011 8:54 pm
by shadrack
thanks mate, i was using the fronts, should i splice into them at the module under the spare wheel, thanks for them colours much appriciated, all the colours on xoutpost vary and contradict each other and never matched mine. might give it a bash tmoro as im off work!!!
Posted: Sun Nov 06, 2011 9:11 pm
by Sanj
That's them and you'll find them in the radio module under all the cr@p.
They will be 2 x 4 with two in the top and two the very bottom.
Don't forget your remote cable for the amp - violet with a white stripe.
And yes, you have no amp if 6 speakers (all in the RCM module)
External amp, in left cubby hole if you have 10 speaker setup (you'll have an extra speaker each side in the rear doors in the leather part plus the bigger ones lower down). No grilles in the leather parts otherwise, quickest way to tell.
Or you then have DSP with the OEM subs in the right cubby hole.
Posted: Sun Nov 06, 2011 10:09 pm
by jeegnesh
[quote=""shadrack""]thanks mate, i was using the fronts, should i splice into them at the module under the spare wheel, thanks for them colours much appriciated, all the colours on xoutpost vary and contradict each other and never matched mine. might give it a bash tmoro as im off work!!![/quote]
no need to splice under the spare although you can most folk tend to splice in the side compartment where the changer is stored you should see those wires in a loom below. Right pain as there twisted together.
Posted: Mon Nov 07, 2011 4:41 pm
by shadrack
cheers jeegnesh and sanj, i got it working this morning, the sounds are ace now thanks
Posted: Thu Nov 10, 2011 12:48 pm
by jeegnesh
[quote=""shadrack""]cheers jeegnesh and sanj, i got it working this morning, the sounds are ace now thanks
so come on what was it???
Posted: Thu Nov 10, 2011 8:41 pm
by shadrack
i spliced it near the cd changer, the colours i was using were wrong of x outpost, thanks
Posted: Fri Nov 18, 2011 8:52 pm
by jeegnesh
[quote=""shadrack""]i spliced it near the cd changer, the colours i was using were wrong of x outpost, thanks[/quote]
cool glad I could help someone
