The car...
Convenience lock on drive off (dealer code option, now also on the Intravee) and then when you come to stop, put the lever into P and the car will 'Unklock' or when you take the key out of the ignition.
Parking sensor sensitivity
- Sanj
Re: Parking sensor sensitivity
dirtymonkey29
Do you mean it locks at 5mpg? Mine already does that.... Do you have a link or anything that shows everything that can be done
- Sanj
[quote=""dirtymonkey29""]Do you mean it locks at 5mpg? Mine already does that.... [/quote]
No that's convenience lock. But then you have to press the centre console button to unlock or pull the door handle twice. The Intravee unlocks the car when you put the gear lever into Park position or take the key out of the barrel, without the need for any intervention.
[quote=""dirtymonkey29""]Do you have a link or anything that shows everything that can be done[/quote]
I've got a pdf doc you can have if you drop me a PM with your email address...
dirtymonkey29
What would be handy is if you had to press the boot release on the key fob twice to open the boot... The number of times I've popped boot putting my keys into the boot
