Page 2 of 3
				Re: Hello !
				Posted: Sun Oct 23, 2011 9:06 pm
				by 535dboy
				[quote=""mikem""][quote=""535dboy""]
Pink M5?
Paul`s isn`t Pink, it`s Brown and never, ever breaks down.
Pinky/brown then !
Or hit by lorries.....
				Hello !
				Posted: Sun Oct 23, 2011 9:58 pm
				by dirtymonkey29
				It can be set via obc if enabled with BMW scanner or can be activated with a timer but it will only blow ambient air temp it will not get hot.  I have tried unsuccessfully for a year now and done lots of research.  You'll find more info on the other thread.
				Re: Hello !
				Posted: Mon Oct 24, 2011 11:05 am
				by mikem
				[quote=""dirtymonkey29""]It can be set via obc if enabled with BMW scanner or can be activated with a timer but it will only blow ambient air temp it will not get hot.  I have tried unsuccessfully for a year now and done lots of research.  You'll find more info on the other thread.[/quote]
After 22 pages, I`m totally confused.
Some are working perfectly
Some aren`t
Some are working with a telesart but don`t function to aid the engine warm up unless turned on manually with fob (since the scanner activation)
Some only blow ambient air.
What I do know is a friend bought the telestart kit and still has it boxed up, unused as his worked perfectly after activation ? Seems a complete lottery
				Hello !
				Posted: Mon Oct 24, 2011 3:44 pm
				by dirtymonkey29
				No I think some people think it's working because the vents come on and air flow can be felt.  On that other thread I have posted a link to a webasto manual.  The difference between thermo z and thermo c are there in black and White.  An upgrade kit will turn a z into a c, which includes the additional pump which is the pump that pushes the hot coolant around the heater matrix.  That is the important bit... Without that extra pump on the webasto the coolant is only pushed around block via the standard pump down by the radiator. I'm in the process of finding out prices for the upgrade kit and also if a fitting kit is also required.  Section 2 of the link I posted gives info and diagrams of thermo z and c.
Hope that helps a bit
				Re: Hello !
				Posted: Mon Oct 24, 2011 3:49 pm
				by 535dboy
				This is why I only ever post stupid things as I never know what you lot are talking about!
				Re: Hello !
				Posted: Sun Oct 30, 2011 8:36 pm
				by mikem
				Re: Hello !
				Posted: Sun Oct 30, 2011 8:44 pm
				by 535dboy
				Looks tidy that mike
One of my fav colours on e53 too.
J
				Hello !
				Posted: Mon Oct 31, 2011 5:18 pm
				by dirtymonkey29
				Nice... Same colour as mine
				Re: Hello !
				Posted: Mon Oct 31, 2011 5:28 pm
				by pvr
				Looking great
				Re: Hello !
				Posted: Mon Oct 31, 2011 5:34 pm
				by x555
				Looks great
  ......apart from the wood trim, just my personal opinion of course
  Sanj will be dead jealous now seeing all that wood again
				Re: Hello !
				Posted: Mon Oct 31, 2011 5:44 pm
				by pvr
				I would be more worried about letting Sanj get anywhere near that £1.20
				Re: Hello !
				Posted: Mon Oct 31, 2011 5:54 pm
				by x555
				[quote=""pvr""]I would be more worried about letting Sanj get anywhere near that £1.20
£1.20
				Re: Hello !
				Posted: Mon Oct 31, 2011 5:55 pm
				by 535dboy
More worrying that you saw that amount of detail
				Re: Hello !
				Posted: Mon Oct 31, 2011 6:00 pm
				by x555
				aaahhh just seen the ashtray
				Re: Hello !
				Posted: Mon Oct 31, 2011 6:13 pm
				by Sanj
				Ha ha, worry about you sometimes pvr...
Lovely car and colour, hope you like it? Now you've had some time with it?
The wood is good albeit I have made a slight change to mine (I get bored too easy).
