Intermitent (SP?) Wiper problem
joncorry
Re: Intermitent (SP?) Wiper problem
Post by joncorry » Tue Oct 11, 2011 9:09 am
Thats a valid point about holding the insurer to account, why should I suffer as the consumer because of their cost cutting? Definately worth a try, thanks for the common sense!
Giles90
Post by Giles90 » Thu Oct 20, 2011 5:08 pm
Can't you clean this sensor?
2004 X5 4.4...to do - nothing! wheels refurbed, amplifier fixed, full MOT, living the dream!
E39 5er various AC Schnitzer mods - gone but not forgotten
Post by X5Sport » Mon Oct 24, 2011 10:17 pm
Not really, no. The sensor is bonded to the glass with a special optically clear adhesive. Once the bond breaks down then there is no way to fix it. The system works by transmitting an infrared beam via the glass and measuring the amount of light being scattered back by refraction and reflection. Water on the screen changes the levels and triggers the wipers. Once the bond goes opaque then that's that. The usual fix, unless you have access to the right bonding agents and hardware to ensure an optically neutral rebond, is unfortunately a new screen.
Giles90
Post by Giles90 » Wed Nov 09, 2011 12:11 pm
I don't know if this helps but there looks like a similar issue on a different forum (don't know if I can post links on here but it's http://forum.e46fanatics.com/showthread.php?t=615032)
If that doesn't work try googleing e46fanatics rain sensor fix. They seem to take it apart, clean it and re-attach with new sealant.
Powercat
Re: Intermitent (SP?) Wiper problem & solution
Post by Powercat » Wed Nov 09, 2011 1:20 pm
[quote=""Giles90""]I don't know if this helps but there looks like a similar issue on a different forum (don't know if I can post links on here but it's http://forum.e46fanatics.com/showthread.php?t=615032)
If that doesn't work try googleing e46fanatics rain sensor fix. They seem to take it apart, clean it and re-attach with new sealant.[/quote]
Giles90 :thumbsup:
an excellent link, what a great find and so easy to follow. if my sensor were to go wrong I would never pay for a new one and now I don't have to, many thanks :D :thumbsup: :thumbsup: :thumbsup:
02 x5 3.0d auto cat D
philip600
Post by philip600 » Wed Nov 09, 2011 5:49 pm
[quote=""petert""]Just checking on this one: the rain sensitive wipers don't detect rain starting, they have to be turned on and they then adjust their sweep according to how much rain is on the screen: you can't just leave the switch in the auto position and expect them to detect rain - that's not how the system is designed. Apologies if you already know this - just wanted to be sure.
Peter T[/quote]
Mmmm, not 100% sure on this but I think they do detect rain ?
I have left mine on auto before & days later the wipers have started automatically when it started raining ?
I'm always amazed how little rain it needs before they start up.
Will check handbook to see what it says.
Phil.
