E53 2003 X5 3.0i auto gear box help
scooby1doo1
Re: E53 2003 X5 3.0i auto gear box help
Post by scooby1doo1 » Sat Jul 23, 2011 4:27 pm
[quote=""CondorX5""]Really good spec there, looks good. And if the dealers a good 'un and gets the box sorted, its a lovely car. I don't think you'll get any fault codes from the box, BTW, as its an internal oil leak past a seal, it won't trigger a fault code. The "trick" of putting it in reverse and Sport Mode a few times is the way to be able to use it from cold, also well known. But I wouldn't be able to live with a box behaving like that - hopefully your dealer knows a good indy who has a rebuild available or will change the seal on yours- let the dealer know what the fault is so he has a good idea, otherwise they may mess about with software and all sorts of other things which will NOT cure the leak past the seal!!![/quote]
Sounds like from what your saying it's a seal, I'll ring erm back before work on monday and inform them of the pos cause or fix for the seal. Does any body no where I can advise the dealers where to take it. Rotherham Doncaster or Sheffield are easy to get to.
scooby1doo1
Post by scooby1doo1 » Sat Jul 23, 2011 4:45 pm
[quote=""wilkoturbo""]Hey your only at Rotherham I'm from Worksop I've got SSS v32 plus BMW DIS that's the software BMW use I could meet ya??[/quote]
i did try ring you twice mate, just went onto answer phone.
wilkoturbo
Post by wilkoturbo » Sat Jul 23, 2011 6:13 pm
Hey no worries must of been on it :)
bmw x5 le mans blue
wilkoturbo
Post by wilkoturbo » Sun Jul 24, 2011 10:19 am
If ya need me today just giz a ring :)
bmw x5 le mans blue
scooby1doo1
Post by scooby1doo1 » Sun Jul 24, 2011 11:25 am
It's ok mate dealer just rung me back 5 mins ago, cheers all the same. If it's no bother to you after i get the car back, i can come to you and plug it in. Then i can ask your advise on buying some software my self.
cheers
scooby1doo1
Post by scooby1doo1 » Sun Jul 24, 2011 11:31 am
Ok so the dealer as rung me back today, 5 mins ago and ask me to ring service up first thing in the morn. I informed him it may just be a seal that needs replacing, i also asked if your guys can't do it, do you send it out to a Specialist, he said yes Quarry Motors in sheffield.
So sounds good, and i'll keep you informed of the out come.
wilkoturbo
Post by wilkoturbo » Sun Jul 24, 2011 3:16 pm
Yeah no worries any weekend will be fine hope the car gets sorted ;)
bmw x5 le mans blue
scooby1doo1
Post by scooby1doo1 » Sun Jul 24, 2011 5:23 pm
ok cheers mate i'll keep you posted.
scooby1doo1
Post by scooby1doo1 » Tue Jul 26, 2011 2:47 pm
Update
I have booked the car in for thursday so there taking a look then, I have asked them to sort the dint out while they have it as well. So be mid next week no doubt till I get it back, they are giving me a mini beast while mines in. 1.6 mini copper in yellow, can't wait lol.
Post by X5Sport » Tue Jul 26, 2011 3:57 pm
I would suggest that if the box has failed so soon after purchase then it is likely you can reject it as not being of 'merchantable quality', or whatever the correct phraseology is, and demand they either fix it, or give you your money back. Fault codes may not necessarily show up and although they are a guide, dealers do try to rely totally on them rather than using their mechanical skills to work out that there really is an issue. I've had issues a few times with the E53 that threw no errors, and it took one of the older guys in the workshop to find it from 1st principles rather than what the computer did (or often didn't) report.
You're looking at a substantial bill to rebuild the transmission - around £2k.
scooby1doo1
Post by scooby1doo1 » Tue Jul 26, 2011 5:26 pm
Hopefully it will be a seal as you say, I like this car and it's got a very good spec. Dint find another like this in the little time I looked.
When I asked about it when I phoned them up, the bloke said if no faults come up they do send it out to a Specialist, Quarry Motors in sheffield. So all been well it's a seal and it can and will be fixed with out any problems. I have ask them to keep me informed and will remind them on thursday when I drop it off.
I will phone up Friday just to make sure that when they tried to drive it first thing, that it dint move. I started back at work on Monday after been off stick. When I got in after my shift it worked, so needs more then 7hrs to not work. It will be left at the garage for about 15hrs so it should deff not work.
Let yous no and up date when more info is at hand, helps others later.
scooby1doo1
Post by scooby1doo1 » Fri Aug 05, 2011 3:18 pm
Well up date time
Just got a call from the dealers, gear box is fixed. Don't get it back till monday, tuesday, as it needs the dint removing. The bloke i spoke to said it was stripped down, cleaned checked, ordered some parts. What parts was ordered he was not sure because the dilan dint ask.
So my question is will putting fresh oil in mask the problem, if this is all what as been done. Just hope they ordered more than just a gasket seal and oil.
Post by X5Sport » Fri Aug 05, 2011 4:56 pm
I would not expect fresh transmission fluid to really make a difference unless the old fluid was filthy. Some say it does, others not. See if you can get a list of parts that have been replaced. If they've stripped and cleaned it, I would expect that at the very least they will have had to fit a new seals kit as well as new gaskets, and hopefully a new filter.
Glad you're getting it back though.
scooby1doo1
Post by scooby1doo1 » Fri Aug 05, 2011 5:19 pm
yep filter to, i'll ask when i pick it up for a list of what was done. Just hope it's fixed cos a go away for 2 weeks on the 18th, so if it's ok when i get it back it will be stud for a while. This then should bring up any faults with the box, if it was not done right.
cheers
scooby1doo1
Post by scooby1doo1 » Wed Aug 10, 2011 6:35 pm
Up date
Got the beastyX back, not before time as well, that mini was ok but just way to small.
Car seems fine for now, and the dint repair is of a very good standard. Can't even tell not on close up to, so will ask who did just incase i need to use them my self.
cheers
