Fitting a Westfalia Detachable Towbar & Dedicated Electric
- wilkoturbo
Really ??? I'll check as I have a new caravan
bmw x5 le mans blue
The fridge should work with 13 pin. I have never had a problem with mine working. On my old caravan I had an adaptor to go from the 13 pin on my car to the 12n and 12s on the caravan and it worked fine.
2015 Space grey 30d F15
- wilkoturbo
It's just someone said the pin that powers the fridge is missin ?!?!?
bmw x5 le mans blue
Re: Fitting a Westfalia Detachable Towbar & Dedicated Electr
nice towbar write up shame i did mine 6 months ago p.s. B5tew i would probly not put a google map to my house on an open forum!
current: 2016 Vw Crafter
[quote=""wilkoturbo""]It's just someone said the pin that powers the fridge is missin ?!?!?[/quote]
mine powers the fridge
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
[quote=""shadrack""]nice towbar write up shame i did mine 6 months ago p.s. B5tew i would probly not put a google map to my house on an open forum!
i dont know why it puts that on there It only does it when I post from my Iphone
Oh by the way it will only power the fridge when the engine is running
- wilkoturbo
That's why thanks , iPhone setting geo tag on/off
bmw x5 le mans blue
The Westfalia wiring kit doesn't have a functioning pin 10 which is for charging/fridge.
Some of the other manufacturers wiring kits do but cost more £150ish Vs £90.
Can anyone with a factory fitted OEM kit confirm wether pin 10 is present ?
What a great write up UrbanFlow ... makes me want to get a towbar AND A CARAVAN just to be able to use your excellent info............
Just got my towbar kit through the post and am using this as my guide to fit. Excellent "how to". Many thanks indeed. If only all "how to's" were the same
If I buy the designated 7 pin instead of the 13 pin wiring harness,.. will the connections in the boot area be the same ie. the white control box and the connecting plug ?
Virgin owner of X5 3.0 D 2003 ( getting to know her better now )(thinking of a long-term relationship now )( sadly now divorced !! )( 4 years later...met the newer model and happy again )
[quote=""DevonX5""]Just got my towbar kit through the post and am using this as my guide to fit. Excellent "how to". Many thanks indeed. If only all "how to's" were the same
Thanks for the comments. Was your fit successful?
Current Rides:
2007 Black X5 E70 3.0D SE - 7 Seater, Dynamic & Media Packs
1975 MGB Roadster with Rover SD1 V8 conversion, Offenhauser Manifold & Holley Carb - Straight lines only.
2005 Honda Hornet with Akrapovich zorst & other odds n sods.
Previous Ride:
2003 Silver 3.0i Sport E53 X5
Previous Ride:
[quote=""jonnyivy""]If I buy the designated 7 pin instead of the 13 pin wiring harness,.. will the connections in the boot area be the same ie. the white control box and the connecting plug ?[/quote]
No idea regarding the connections - but I would assume that they would be just plug and play if they are the Westfalia kit as they are what BMW supply and fit.
If you are going to the trouble of fitting it yourself I would suggest going for the 13 pin set up and using a 13-7pin adapter like I do (they cost less than a tenner from a decent towing shop or online). With just a 7 pin electrics system fitted you'll put off people with caravans when you come to sell the car. Just a thought.
Current Rides:
Previous Ride:
Previous Ride:
Good suggestion,.. never thought of that,.. I have a caravan with both black and grey plugs but I've never used the grey one for charging the caravan and chilling the fridge. There's been a debate on here already about whether the fridge will work off this 13 pin system ??
