I bought new it was £392.30 plus vat for testing all injectors and 1 new injectorrockwell wrote: Mon Nov 06, 2023 2:17 pmDid you recondition the injector or buy new?Lobster Pot wrote: Mon Nov 06, 2023 11:41 am I had all 6 tested and just had the 1 faulty injector replaced
P Atkins in Mansfield tested mine but like I said the injector wasn’t the main problem and still wouldn’t run right after replacing it
E83 X3 3.0d 2006 155,000mls total failure
Lobster Pot
- marti
Yoiu can buy a remanufactured one for a lot less.
rockwell
Probably a naive question but did they remove all six to test? Just wondered if there is a method of testing in situ.Lobster Pot wrote: Mon Nov 06, 2023 11:41 am I had all 6 tested and just had the 1 faulty injector replaced
I'm perfectly happy for all six to come out, but in a 2006 car I guess some or all will be brittle to say the least!
Lobster Pot
Hi yeah I had all 6 removed by garage then sent to atkins to be testedrockwell wrote: Sat Nov 18, 2023 3:11 pmProbably a naive question but did they remove all six to test? Just wondered if there is a method of testing in situ.Lobster Pot wrote: Mon Nov 06, 2023 11:41 am I had all 6 tested and just had the 1 faulty injector replaced
- marti
The Injectors wont be brittle...theyre made like tanks
rockwell
Just a brief update on this. I've been away so the car was in my garage at home for some time.
Last week all six fuel injectors were removed, surprisingly they came out very easily considering they've been untouched since 2006. I followed Lobster Pot's advice and sent them for testing to the same company he used. 4 failed and 2 are fine. Replacement Bosch injectors will be fitted next week so will update.
- marti
All will be good then
rockwell
Thanks Marti, glow plugs being replaced at the same time. just hope there are no further problems caused by the faulty injectors....possibly compression issues?
- marti
I doubt it.....
Might be worth replacing the glowplug controller as well. It isn’t unknown for failed plugs to cause the unit to pack up shortly after the plugs have been replaced.
rockwell
What a transformation! four new injectors, a few gaskets here and there, new glow plugs and my X3 sounds like a very quiet petrol engine.
MPG has increased to around 38 - 42ish. Thanks to everyone for the help and advice. X5Sport - they also changed the glow plug controller.
Glad that you got there in the end. Enjoy more miles with smiles
Never anthropomorphise computers. They hate that.- marti
Happy days
rockwell
One small job I forgot is the third brake light above the rear window. It appears water may have got in and blown something. I had no idea its an MOT failure. I already have the light strip, just need someone to fit it.
rockwell
I ordered a third brake light from Autodoc but sent it back as it was for a different model. Does anyone have a suggestion as to where I could pick up one of these? I've checked eBay but didn't like the look of one I saw for sale from a breakers yard.rockwell wrote: Sun Mar 31, 2024 4:54 pm One small job I forgot is the third brake light above the rear window. It appears water may have got in and blown something. I had no idea its an MOT failure. I already have the light strip, just need someone to fit it.
