2004 X5 With A Constant Vibration
Only as above suggestion. I think you mean drive shaft?
Never anthropomorphise computers. They hate that.- Greydog
I did have vibration on the E53 4.6is which started at around 2.5k rpm (road speed around 70+) It turned out to be a failing bearing on the transfer case out put to the front drive shaft. BMW were not interested in selling parts just a new transfer case complete exchange (Big surprise not) Found a replacement from Quarry Motors (less than £200) no vibration any more. Out of curiosity I stripped the old case and pulled it apart pressed the shaft and bearing out, the part number on the bearing was Meter bearings in the USA $35 plus shipping. re-assembled it with a new chain gaskets and fluid. Sold it to a guy who brought a 4.4 E53 really cheap that had a suffered from wrong tyre set up, he is still driving it daily.
Kuzzie
Got an mot this week..... Picked up OSR subframe bush worn..... Let's see if it could have been the issue
- henrym3
Years ago I had a vibration including at idle, took the auxiliary belts off and no change, noticed what looked like oil on one of the engine mounts so changed them. Cured, I would mention that the one with oil was fine still stiff to move the the other one which looked fine was completely shot. I changed them on the off chance as I couldn’t think of a way to definitely test. Don’t like throwing parts at a problem but in this case it worked.
