TRAFICA
Greydog
Re: TRAFICA
Post by Greydog » Fri Jul 31, 2020 7:46 am
Morning Henry
Been a pain in the neck for you so far lets hope the pressure sensor fixes it. As our cars are similar age and probably mileage this will be filed away.
Don't worry about the Passat owner he should notice at the gate post :rofl:
Dave
Re: TRAFICA
Post by X5Sport » Fri Jul 31, 2020 10:20 am
We had that sensor (or its equivalent) fail on the E46 and I was very surprised at just how expensive they are!
Re: TRAFICA
Post by henrym3 » Fri Jul 31, 2020 2:51 pm
If it was a guaranteed fix I’d probably buy new so I’d rather try the £5 jobbie first even though I’m aware that it’s only a year or two newer. Hopefully that’s not why it was scrapped :( Just such a PITA to get at to take 20 seconds to change the sensor.
Re: TRAFICA
Post by henrym3 » Sun Aug 02, 2020 9:06 pm
So, I changed the sensor today and all is good, no lights. Initially I just took the plug of the sensor and plugged the replacement into it. Lights went out so I had reasonable confidence replacing the sensor would fix. Once I had the old sensor out I plugged it in and it still read 292 bar. Definitely bad sensor. You loose some fluid on change over so had to bleed again.
A real PITA to do
Greydog
Re: TRAFICA
Post by Greydog » Mon Aug 03, 2020 7:15 am
Great job Henry
It may have been a PITA but you beat the little beast. Now lets hop for a peaceful period !!
Just to keep me on my toes the X5's passenger door actuator died on Friday, fortunately our local yard had just got an X5 in so able to fix yesterday :D
