Re: Engine code question
Posted: Wed May 13, 2020 12:18 am
				I think diff failure was very rare, judder on steering  lock at low speed is often the transfer box, a rumpling  like driving on a motorway rumple strip as you drive in top gear can be the torque converter on the way out and slipping. Suspension inactive is compressor or airbag leaks.
Is its laggy at low revs the small turbo isn't doing its job on the sd/35d engine.
Sunroofs are prone to failure and need complete 3k replacement as they are not fixable but nice to have. Heated seats a must and xenon lights.
28mpg is a realistic best for older e70's
If the tail pipes are not clean run away as the particulate filter is broke/ missing and will be very costly to fix.
