Heater/blower question
weirdfish
Re: Heater/blower question
New resistor ordered through Cotswold, pick it up Thursday when I'm in Cheltenham anyway.
Went out this morning to a flat battery, I'm thinking it's down to the resistor, or else I have another problem to deal with, lol.
I decided to see what sort of job it's going to be and removed the old one, it's either the fact that I have hands like shovels or just not as bendy as I used to be, ended up looking like I've been attacked by some sort of animal, bloody sharp bits up there.
- henrym3
Well, I suppose if your battery survives till Thursday you’ve cracked it
weirdfish
Hooked it up to a trickle charger, so hopefully by the time I fit the new resistor it should be ok.
weirdfish
Thought I would check the battery as best I could whilst waiting for the new resistor, it's been hooked up to the trickle charger for a good few hours now so a quick check with a multi-meter revealed that it's showing just under 12v when nowt running and just under 14v with the engine on tick over.
After switching the engine off and waiting a few minutes I decided to see if there was anything still drawing on the battery, hooked up the meter again on Amps setting and it showed 0.04 when set at 20A, so I would conclude that this is pretty much ok.
Once I fit the new resistor I'll go through the settings again to double check.
- sleepyfolk
You might find that battery is old and knackered anyway if it’s been on a car that’s had a drain or fan problem that no one fixed, I know you haven’t seen the fan running of its own accord yet but if you do get funny messages and warnings coming up after you’ve fixed the fan consider your battery as a suspect!
weirdfish
Already considered changing the battery, these things need to be at the top of their game really.
I actually got a price from bmw at the same time as ordering the resistor, pleasantly surprised at around £120.
- sleepyfolk
I paid about that for a Bosch s5 from ECP with one of their usual offers
- Paulpen
Under 12v with no load is toast and is going to let you down sooner or later
weirdfish
Dont forget it was flat and I’ve only connected it to a trickle charge optimate type of charger so it might want a bit longer to get fully charged.
I’ll re-check again after fitting the new resistor and giving it a good run.
- Paulpen
You might need a reconditioner more than a charger if its been flat more than once
