E53 X5 Accelera Iota Tyres - any good??
Re: E53 X5 Accelera Iota Tyres - any good??
2004 is a facelift E53 so will have Xdrive, 4.6's were pre facelift as they went to 4.8 at facelift.
It that makes it clearer
- sleepyfolk
X-drive comes with the facelift model in 2004 I think, I also thought I’d read in here if people discussing transmission problems on pre-facelift due to cheap tyres, maybe I didn’t need to get posh ones but hopefully they’ll last a while!
Mercedes CLK 320
Audi A6 Quattro 2.4
Mercedes CLK 320
Audi A6 Quattro 2.4
blackthorn79
I’ve had the accelera on for 5000 miles now. No issues at all & no signs of wear
wpoll
Cheap tyres aren't what screw up the X-Drive transfer case - it's mis-matched tyres, which is a compromise folk often make when trying to save money on tyres.
With X-Drive it is critical that all four tyres have the same rolling circumference. For example, if you have worn tyres (say down to 30% or original tread depth) and get tyre damage that ruins one tyre, you must replace all four. Unless you can find a used tyre that is similarly worn as your other three. Good luck with that.
A bugger to be sure but a still a fact. The differing rolling circumference on the one new tyre will "wind-up" the transfer case causing it to slip when driving and wear it out prematurely. Very prematurely.
YMMV - literally.
YMMV - literally.
Richyroos
Forget that query - I checked on Realoem, and it appears that the transfer box changed to the xdrive type in mid 2003, so mine is an xdrive.
If in doubt, and all else fails - read the instructions!!
Current car : 2004 E53 X5 3.0D
Handy mine is 2002
Richyroos
I am beginning to think buying an X5 was a big mistake _ I have never had a car that demanded a set of 4 new tyres if you punctured one tyre and the others are half worn. It doesn't seem a wonderful design, not having a centre diff, relying on a clutch to provide the slip, to me it would have made more sense to have had a limited slip centre diff, or one that could be locked under poor conditions.
I had a Land Rover many years ago, I know that if you engaged 4 wheel drive on that, you ran the risk of winding up the transmission, or wearing the tyres badly, as there was no centre diff - hence free wheeling hubs were often fitted. I personally used 2 wheel drive nearly all the time.
It’s not just the E53, or limited to BMW! Merc and Audi have their own ‘special’ tyres and owners of Škoda Superb 3 models with the 4x4 option are starting to note problems unless a fairly closely matched set of tyres are fitted.
My (untested) theory is the manufacturers have gone for weight over performance and once a car is out of warranty they no longer care as in their view the vehicle is end of life and please come and buy a brand new model! Built in obsolescence I think it is called. Whatever it is, it isn’t right.
It could also be that outside the US, car manufacturers have a far easier time with litigation - just look at VW and how little they have had to do in Europe compared to the $Bn paid out in the US.
I’ll be interested to see if my 220 Gran Tourer also needs ‘*’ marked tyres. It has xDrive fitted but a ‘square’ wheel setup.
Richyroos
Now some of you guys have "frightened" me - I have ordered a further 3 Nexens to replace the other 3 tyres, so they are all new - apart from the one Nexen I had to buy recently, but that has only done about 800 miles, so all 4 will be essentially "new", and all the same make, and so should be good. Hopefully no transmission problems now!
- Murphybarnes
I have some sympathy with the OP. I was hamstrung when it came to tyres and Toyo Proxes was all I could stretch to. I recognised (through this forum) that * marked tyres were clearly the only option with a staggered set up but realistically in real world terms not always possible.
The E53 is a difficult car to enjoy sometimes and if I'm honest if I knew then etc.. ...
If you buy an e53 and rag it it on the cheap then fine. But if you join an e53 forum then you clearly have more than a passing interest.
It's all gospel mate, and well worth adhering to.
2006 3.0d Le Mans.
- briankerrys47
[quote="Richyroos"]
Hi have been on Nexens for 6 years and 17000 miles still plenty of tread,the car had usual missmatched tyres all diff ,inner wear on rears rectified when osr bottom ball joint fitted, price at time front pair £242 rear £275 fitted
nyumahmobiletyres
thanks for information
- henrym3
I’ve been running 22" wheels on my 2002 4.6 for nearly 10 years. The last set of tyres I bought over a 2 month period (financial constraints) I bought a set of accelera for the front and then discovered they didn’t do the 315 size for the back so bought Goodyear f1. I know you shouldn’t mix but it is a 2002 with the sensible transfer case. Anyway the Goodyears are worn out at 33k and I have 4mm left on the Accelera tyres. However as I’m now well into my 70s my back seems to need a lot more love so I’m returning to the 20" wheels. I’ve just ordered a set of staggered Accelera £77 per front tyre and £89 per rear tyre, they should be here by Thursday I also bought a set of tyre pressure sensors at £49 arriving tomorrow. I think out of interest when the tyres arrive I’ll put some chalk marks on them and as I have a nice flat floor in the garage I’ll roll them along and see if there is much/any difference in the circumference of the different size tyres before and after fitting to the wheels. Not that it matters much on a 2002 but will be interesting.
I had a full set of Accelera Iotas put on my staggered 20"s a few months ago. No problems at all. Fitted cost £470 so good price too.
I've always had Accelera tyres where I could as they are pretty good in my opinion.
- henrym3
I’m not greatly knowledgeable on tyres but when you look at the stats that go with tyres ie noise wet grip dry grip the Accerlera are always up there and sometimes better than something twice the price.
