	Battery drain found but not solved
				tommy2704
Re: Battery drain found but not solved
now sorted. it is defiantly the tv module causing the problem. when I disconnecting this alone the drain disappeared. so do I need to replace or can I repair??
				tommy2704
it was the tv module. all working fine now. thanks for the help
						- marinaman
- Contact:
do you chaps think this hedghog could the cause of my drain, i barely use car but after 1 week after a full charge on the ctek charger its back down to 50%   then a week later 30% when it tells me to charge it again
			B&B by the sea in sunny Bridlington, best rates for members   www.themarina-bridlington.com
