4.8is - cracked open front diff
IanP
Re: 4.8is - cracked open front diff
Post by IanP » Tue May 09, 2017 5:03 pm
^^^^ That's what I thought. Not so much the difference in wheel speeds, but the sudden stop as the front wheels climb off the rollers.
Nat
Post by Nat » Tue May 09, 2017 5:17 pm
I am NOT an authority on this but every time I  have taken  the X5 for an MOT ( I go to the same place every time ) and have had 2 E53's ( 4.4 and 4.8iS) and currently have a 40D every single time without exception the MOT tester avoids the rollers and the brake test is done in a completely different way.
I think it even tells you in the handbook that the X5 should't go on  any rollers / dynos.
I have to tell you I would be looking at the MOT station to make good.
They were in the car and it broke whilst they were testing it.
I am sure they have insurance for this.
centurion
Post by centurion » Wed May 17, 2017 12:31 pm
Thanks Nat... that is the option i will explore too.
I did manage to source 2nd hand diff and the car is back on the road... i hope it will last this time round.
As a "precautionary matter", Oil was drained and replaced in a rear diff as well as the transfer box.
Steamyrotter
Post by Steamyrotter » Wed May 17, 2017 9:42 pm
i hope you didn't put oil in the transfer box???
think that's meant to have ATF in it??
But am assuming you refilled like for like though.
centurion
Post by centurion » Thu May 18, 2017 12:52 am
I didn't :-)... a garage that did the work on the diff and suspension replaced it.
