Re: Tyre Replacement
Posted: Wed Nov 16, 2016 12:41 am
The gearbox isn't the issue with the E70, it is the front/rear diffs or the xDrive unit (transfer box) that goes.
You can try swapping front to rear as I can't think of any obvious problem. You are predominantly RWD unless the xDrive thinks it is necessary to switch over. Non-staggered set ups are far less problematic but you do still to stay within probably 2mm front to rear difference, possibly a bit more but not much.
X-drive is all wheel drive all the time...
