Re: Rad Fans
Posted: Sat Oct 29, 2016 7:48 pm
I work with refrigeration a bit in my job as a Compressed Air service engineer. Most standard pressure switches are Normally closed circuit if the pressure is above their ( happy ) pressure. When the pressure drops bellow the happy pressure, so they go open circuit, usually resulting in a non working system.
You can usually bridge the switch to briefly try the system, not long enough to cause damage.
The correct way is to have your
Reassure gauges connected to see if the gas pressure is up to normal system pressure.
Some pressure switches are shraeder mounted so are fitted so can be changed without vacuuming out all the gas, some are brakes in.
You need gauges that are suitable for R 134A gas usually. If the pressure is ok, then try with the pressure switch bridged out to test.
As usual X5 Sport types faster than me
