I work with refrigeration a bit in my job as a Compressed Air service engineer. Most standard pressure switches are Normally closed circuit if the pressure is above their ( happy ) pressure. When the pressure drops bellow the happy pressure, so they go open circuit, usually resulting in a non working system.
You can usually bridge the switch to briefly try the system, not long enough to cause damage.
The correct way is to have your
Reassure gauges connected to see if the gas pressure is up to normal system pressure.
Some pressure switches are shraeder mounted so are fitted so can be changed without vacuuming out all the gas, some are brakes in.
You need gauges that are suitable for R 134A gas usually. If the pressure is ok, then try with the pressure switch bridged out to test.
As usual X5 Sport types faster than me
Rad Fans
Re: Rad Fans
Re: Rad Fans
Goes off to read up on Schrader valves. Second time that name has come up this week.....in different places. ???
Don't bore the others.....
Never anthropomorphise computers. They hate that.- Steamyrotter
Re: Rad Fans
Basically the same as those fitted to your tyres!!
Will seal until centre pin is depressed.
Davrosbimmer
Re: Rad Fans
My aux fan doesn't run....just been diagnosed with a condensing rad and fan...ouch!
BMW E30 327i Cabrio
BMW E30 316i Touring
BMW E32 730i
BMW E39 525i Touring
BMW E92 330i
Mercedes SL320
Audi A4 Avant quattro
BMW E53 4.6is (current)
BMW E32 730i
BMW E92 330i
Mercedes SL320
Davrosbimmer
Re: Rad Fans
Actually...BMW got the fan to run..it was just the condenser at fault. Got a new one installed by a main dealer and it's lovely now.
BMW E30 327i Cabrio
BMW E32 730i
BMW E92 330i
Mercedes SL320
BMW E32 730i
BMW E92 330i
Mercedes SL320
strummer
Re: Rad Fans
which condenser is this?
- henrym3
Re: Rad Fans
My understanding of the condenser is that it is just a radiator to cool the gas to a high pressure liquid for onward travel, the only thing that can go wrong is a stone puncture or leak by bad connection, which begs the question as to how it passed a system pressure test as mentioned earlier on? and how the a/c worked fine. Anyone like to increase my knowledge?
VW R32 Gone
VW R32 Gone
Re: Rad Fans
Matches what I thought too. It's just a rad with a drier unit built in. It either works, or has a hole in it and doesn't.
