Rear passenger side suspension low
Re: Rear passenger side suspension low
[quote="Graeme"]
It happened to mine about 6 weeks ago. From memory, a replacement part from BMW was about 240 +VAT. I got an Arnott unit for half that from Europarts delivered to the workshop in an hour. It took my indy mechanic less than half an hour to fit and that included checking the other bag, compressor and pipe unions. Total cost - less than that for the BMW part. It's a straightforward process and the change does not affect the sensor that controls the variable height of the rear.
Arnott have a good You-tube video to show how it's done. https://www.youtube.com/watch?v=7WXxrI5QFdk
Brilliant
Will check euro car parts
Came back and was fine with it being parked up several hours, so will keep an eye on it
Will it affect wheel alignment?
Brilliant
Examination of the leaky bag on mine with soapy water solution showed a small row of holes along the line where the bag folds as it's compressed/stretched. If you push the sleeve of your sweater up your arm you'll see it fold, pull it down, push it up etc and it will fold at the same place. On the suspension bag this folding will eventually cause a weak spot in the rubberised canvas along the line of the fold. The soapy solution on mine showed the other bag was intact.
The leak is slow, so the compressor will pump the car up quickly and it will take several hours to deflate. I can't see why it should affect wheel alignment as the sensor controls the compressor to hold it level front to rear.
[quote="celica"]
[quote="pcdee"]
[quote="celica"]
If it's one of those parts then not too pricey
Will find out how much from dealer
Wonder how long it takes for a competent mechanic
But here is how it looks
Got mine done 2years back at Mr Clutch for under £100 for both.
Took them under an hour.
Sent from my SM-G900F using Tapatalk
£100 for both parts and labour!?
Just labour mate.
[quote="pcdee"]
[quote="celica"]
Just labour mate.
X5 E70 3.0D SE
Thanks, hope my local go to mechanic will be similar or less on labour
What part did you use?
I can't find any on eurocarparts
Anyone know if it affects alignment
I can't answer your question fully except to say I know he phoned Europarts in Darlington and they had one in stock which they delivered to him. It was an Arnott manufactured part.
I see arnott on google, they are cheaper than BMW supplied but more expensive than eBay apparently oe quality ones
Well, it was a case of "needs must..." because the car was needed the next day to carry quite a load. The part was there, the BMW part was also available immediately at twice the price. Searching Ebay and getting delivery would have taken a couple of days. The Arnott part from Europarts is warranted, and when checking it on arrival it was identical in size and fitments to the defective unit, so it seemed the most cost effective solution when time was of the essence.
Hi Celica. You're not having a good time with this X5 are you. :'(
The rear air thing is another one of many common X5 failings. I did mine a while back.
See http://xdrivers.co.uk/forum/index.php/t ... #msg112817
Bought from p38spares. see also this thread...
http://xdrivers.co.uk/forum/index.php/t ... #msg121519
I'd do the pair, if one has failed the other will follow.
Took my indie 1 hour to do both! BMW I think charge 2.5 hrs of silly rates.
3.0SD E70 M Sport.
Z4MR E85
Z4MR E85
Thanks both
And yes not too much luck as of late
Also first car which has been problematic as much as this which is annoying
Thanks for the links
Might go for the aerosus
As they are cheaper than arnott, German made with 2 years warranty
[quote="celica"]
Thanks both
I have Areosus on mine.
They are cheaper and I've had them for over 2 years now without any issues.
I ordered through Amazon Germany.
Thanks both
X5 E70 3.0D SE
Pcdee
I'm still waiting to hear back from mechanic
Not much reviews on aerosus vs arnott which made me start thinking on quality
But a single arnott is about £190 whilst can get a pair of aerosus for same money
Decided to stay away eBay non branded ones though
Looked through ECP and GSF but nothing
Updated in the following thread for reference
http://xdrivers.co.uk/forum/index.php/t ... 482.0.html
[quote="pcdee"]
[quote="celica"]
Same happened to mine, bought a pair of airbags from ebay for about £70, fitted by my local mechanic £50 although he could not fit one of them as the profite was not the same as the other side and air pipe would not stay attached. Fortunately, not the faulty side and he thought the non-faulty one had been changed within the last year.
I too had a Celica before the X5 - I miss that reliability!
[quote="celica"]
Mines just went 2 nights ago. Noticed it was leaking gradually over night for a few weeks. But Saturday night there it came up with a warning "system level failure" and the rear passenger side just dropped. Luckily was less than a mile from home. Called in a favour and got it fixed yesterday (Monday). Part was from euro I'm sure and I paid all in £214 that's labour included. Think that's not to bad considering I was expecting nearer £400 to £500. Took less than an hour to do at local Indy.
2010 X5 xdrive40d in Bronze
