Considering an X3
jagr
Re: Considering an X3
Post by jagr » Thu Feb 25, 2016 9:52 pm
How to identify from interior:
Early:
Facelift:
You can see the dash plastic quality differences and the facelift has the fascia pieces.
Also facelift have door pockets and pre-facelift have a netting.
They don't all have satnav, in fact very few do.
**As said don't be put off by a new turbo. My '56 had a new turbo under warranty @37k by BMW**
2011 BMW X3 30d M Sport
shorn
Post by shorn » Thu Feb 25, 2016 10:41 pm
Thanks, very useful. Your first se looks really nice. I like those running boards!
shorn
Post by shorn » Thu Feb 25, 2016 10:42 pm
What the connectivity like? I'd like to connect in an iPhone. What options are there for this. I don't suppose there's any aftermarket CarPlay head units that fit as the only ones I've seen need a double din. Assuming most have Bluetooth?
jagr
Post by jagr » Thu Feb 25, 2016 11:04 pm
In my current X3 I have the BMW bluetooth and it works fine with my iPhone 6.
The facelift X3's have an AUX in behind the front armrest.
In my old X3 I brought this back from the USA and it was brilliant:
You use it in conjunction with the existing stereo.
It gives you bluetooth,MP3,SATNAV,Movie playback and audio/video input.
I put movies and music on a USB stick and played them from that.
I also fitted a reverse camera into the boot handle and connected it to the screen.
Post by AW8 » Thu Feb 25, 2016 11:15 pm
Useful pics there jagr.
I would add it can be difficult for untrained eye to tell difference between pre-facelift & facelift. Later cars have more paint on bumpers but msports can confuse. Also front lamp configurations vary. I find easiest visual clue is the nose grills - significantly bigger only the facelift.
Maybe jagr might have front comparison pics. If not just search classified advertising sites....pretty obvious once you see some images or cars in the metal.
shorn
Post by shorn » Thu Feb 25, 2016 11:45 pm
Thanks for that jagr. When you say the BMW Bluetooth works fine with your iPhone 6, is that just for calls, or can you play audio as well?
jagr
Post by jagr » Thu Feb 25, 2016 11:46 pm
[quote="shorn"]
Just calls
If i want to play music from the iPhone I use a jack cable to the AUX in
jagr
Post by jagr » Thu Feb 25, 2016 11:50 pm
Pre-Facelift SE (my mates old 2.5se):
Facelift (my old SE):
jagr
Post by jagr » Thu Feb 25, 2016 11:53 pm
There is also the Aerokit which is a BMW aftermarket add-on
This is my mates '05 2.0d Sport with Aerobat which was around a £2k option that was fitted when the car was 2 years old:
jagr
Post by jagr » Fri Feb 26, 2016 12:03 am
[quote="AW8"]
As AW8 says they are confusing as I actually went to see a 2008 '08 X3 that was a prefacelift so registration does not help.
As you can see it has old rear lights (non LED style) and Msport bumpers but it is a pre-facelift.
Its a mishmash
kkx5
Post by kkx5 » Fri Feb 26, 2016 5:45 am
Its not 08. Fake plate.
Post by AW8 » Fri Feb 26, 2016 11:54 am
Please qualify last post.
Car probably since totalled or on a cherished transfer.
I believe there  were some left over prefacelifts registered in 2008.
jagr
Post by jagr » Fri Feb 26, 2016 12:36 pm
[quote="kkx5"]
It is a genuine '08.
It was on a private plate.
kkx5
Post by kkx5 » Fri Feb 26, 2016 3:40 pm
Just cant be. Did you get it scaned to check production year/ engine code.Face lift starts 09/2006. 2008 non face lift? Impossible even in UK.
Post by X5Sport » Fri Feb 26, 2016 3:43 pm
Perfectly possible if it wasn't registered until 08.  Build date isn't relevant to registration year.  Worth checking just in case though as it just gave been in unsold storage for a while  ;)
