[quote="marshyrob"]
Hey Mpower, Can i code this option in myself? Been thinking about doing so coding so if this is something i can do then its even more tempting.
I assume adding the option to the VO is the coding part but activating the SA620 would need a FCS code?
Rob
It can be done by script coding but if you have no experience I would take your time reading and get the basics absorbed first.
Try simple codings first and when you've got the hang of it and fully understand what's in hand to enable sa620 no reason why not code it it yourself but as with any coding from factory there will be a risk of bricking your CIC with wrong inputs.
Hope this helps.
Lee
X5 E70 Voice Control
marshyrob
Re: X5 E70 Voice Control
thanks Lee
Intend to start off slow and make my way on from there.
