Page 2 of 2
Re: Scanner 1.4.0 help, much needed
Posted: Sat Oct 18, 2014 3:11 pm
by Ant
Horizon, yes thank you, I have scanned the car, and I am looking for faults with the alarm, nearest I can guess is as stated previously, so if anyone knows what that code means, or where exactly I should be looking if I am in the wrong area
Ta
Posted: Sun Oct 19, 2014 1:05 am
by Smeeagain
Well done on proofing your way into the car.
The first thing I would do is tick the box to clear all errors the run it a couple of days to see what if anthing comes up. It's simply trial and error to open up various pages. You can't really go wrong other than if I remember correctly you don't want to overwrite EEPROM codes if you don't know what you're doing. I'm sure someone else will advise
Posted: Sun Oct 19, 2014 10:57 am
by Ant
I have sat and deleted some of the error codes, and I will run it and try again in a week or so.
I did find an error relating to the bonnet sensor eventually, and I think it was just shorting due to that days weather. I still have various error codes that are not moving, so a definitive list of codes will still help.
ALSO, as is my luck, the first two sections on the scanner, DME & EGS are 'not found' ???
Any ideas (in lay-mens terms) how I can fix this?
Ta
Posted: Sun Oct 19, 2014 11:20 am
by Horizon
Posted: Sun Oct 19, 2014 11:42 am
by Ant
Thanks for that link
Looks like I wont be getting a reading from my computer, I cant even work out if the thing they are welding is the plug I bought or the plug in the car  :-[
The first two photos in the thread will not open (probably removed due to age)
Does this mean that if I took my car (2003 X5 4.6iS) to a dealer/specialist THEY would not be able to read my car correctly either ?
Posted: Sun Oct 19, 2014 12:04 pm
by davesavage257
It's the connections in your lead that you've bought, not the car, that will need jumper wires soldering so it can read those modules.  My scanner came correctly wired, so I have no problems with reading those modules, but I understand that some need a bit of modification to work fully.  A specialist would be using something more sofisticated than Scanner 1.4.0 and would have the correct connections.
Dave
2003 BMW X5 4.6iS Auto
2007 '57' Saab 9-3 Aero 2.0T Auto
Posted: Mon Oct 20, 2014 9:59 am
by Ant
Thank you Dave, I have a mate who can solder, so it will have to go to him
Is it 7 & 8 that need joining ??
Posted: Mon Oct 20, 2014 10:49 am
by Raj
Alarm going off is a common issue with the bonnet switch. I actually just disconnected mine lol.
Posted: Mon Oct 20, 2014 12:03 pm
by Ant
Touch wood, now its dried out the alarm is playing ball  8)
Posted: Mon Oct 20, 2014 1:10 pm
by Raj
[quote="Ant"]
Touch wood, not its dried out the alarm is playing ball  8)
fingers crossed.
