Possible group buy - DI Vessel
pvr
Re: Possible group buy - DI Vessel
Post by pvr » Tue Jun 26, 2012 11:04 am
Yes, that 2 hours work a day takes it out of you  >:D
Still can't believe that water reading of yours, your tea and coffee must be quite "muddy"  :))
You can start a group buy for the resin for yourself only ...  :P
What reading do you get from the vessel output?
Post by X5Sport » Tue Jun 26, 2012 5:22 pm
Oi!  It's 5 hours a day now, thank you....... >:( :P
All drinking water is filtered anyway so that isn't a problem.  We do have lime-scale problems with the heating (dosed annually with Fernox) and other things like washing machines and now I know why!!  Good thing Mrs X5Sport uses these anti-scale tabs!
Haven't yet tried the DIV yet as I have just rigged up a particle filter to sit between the Karcher Pump and the DI vessel.  I think I will be running off the water butt for now as the water is kept much cleaner with the pour in treatment that can be bought, and at 40ppm and so much water...err....'falling' at present it's an easy choice.
The Karcher 3800 does have a simple foam filter and I also have the Karcher addon one for the front of the K6.800 PW (it might also fit a number of the recent/current models too I think?) which I have now added a Hozelock 2289 adapter to so that it makes a very cheap in line particle filter with a male Hozelock at each end.
The only in-line particulate filters I have come across are silly money and hence my wanting to rig something much simpler up.  OK it won't go down to sub-micron level, but it should keep anything else out of the resin.
I did have a look at Anglian Water's website and it seems this area is amongst the hardest water supply areas they serve.
DI Vessel - VERY impressed
Post by X5Sport » Wed Jun 27, 2012 6:51 pm
Have connected the black beast up to the mains water supply today to see what it can do.  I'm VERY impressed.
Water Main pre-DI Vessel input....TDS = 500ppm +/- 10ppm
DI Vessel Output.......TDS = 1ppm.  :D :D
It took almost a minute to change from 0 to 1, but that really is a result.  Now just need a long enough dry spell to use it in anger.
Raj, pvr.... :bigthanx: :bigthanx: :bow: :bow:
mogsyman
Post by mogsyman » Wed Jun 27, 2012 8:50 pm
I used mine tonight but didn't take a reading.
Will be interesting to see the 'lack of' water stains tomorrow morning.
As has been said, thanks Raj!
Sent from my iPad using Tapatalk HD
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
pvr
Post by pvr » Wed Jun 27, 2012 8:52 pm
It will be the boot and near the joints where the stains will be if you have not rinsed enough "clean" water through there.
Mistakes I made in the beginning when I was an innocent beginner, like you lot  :))
mogsyman
Post by mogsyman » Wed Jun 27, 2012 9:25 pm
[quote="pvr"]
Did you make the pressure mistake and get soaked.....
I did :)
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
Post by X5Sport » Wed Jun 27, 2012 9:27 pm
Having read the warnings above, I was well clear.  One of our Bengal cats wasn't though.......but then they love water!! :P
Soggy Moggy!! :)) :)) :))
dirtymonkey29
Post by dirtymonkey29 » Wed Jun 27, 2012 9:41 pm
Ok I'll bite seeing as its probably expected of me lol.
You cant beat a wet pussy!
Post by X5Sport » Wed Jun 27, 2012 9:44 pm
:doh: :laughing1: :laughing1: :laughing1:
dirtymonkey29
Post by dirtymonkey29 » Wed Jun 27, 2012 9:49 pm
[quote="dirtymonkey29"]
Light spanking is acceptable though
Post by X5Sport » Wed Jun 27, 2012 10:18 pm
If I was you I'd quit while you were still ahead........ :)) :)) O:-)
dirtymonkey29
Post by dirtymonkey29 » Wed Jun 27, 2012 10:24 pm
I think you could be right lol
pvr
Post by pvr » Thu Jun 28, 2012 9:24 am
Shocking behaviour  :))
Post by Raj » Thu Jun 28, 2012 10:25 pm
Leave you lot alone for a little while and see what happens.....lol
Post by X5Sport » Fri Jun 29, 2012 11:53 am
If the weather holds I will defo be using mine this weekend.  It looks like someone dumped part of the Sahara around here.  Everyone's cars are absolutely filthy after just one heavy rainstorm!!  As it come from the southerly direction, what are you lot in Sussex up to?
