CHANGING 3.0d breather assembly
How-To articles ONLY go here.
Jamee
Re: CHANGING 3.0d breather assembly
Post by Jamee » Thu Mar 28, 2013 11:07 pm
[quote="bazzyboy"]
SERVICING THIS PART WILL EXTEND THE LIFE OF YOUR TURBO <!-- s;) -->;)<!-- s;) -->
the breathers job is to stop excessive build up of crankcase pressure in the oil system
which can blow seal & gaskets & PUT STRAIN ON YOUR TURBO
have you ever seen a engine smoke when you unscrew the oil cap this is crankcase pressure
TO STOP THIS
change ur breather every 20k if short journeys & every 30k if long trips mainly its only £19+vat if u have the modded breather which came out in 2005 if u dont u
can change to the new design for £40+vat
part no--modded Breather assembly----- 11127799225 --£40+vat
partno--filter assembly for breatherif have modded style housing------ 11127799366---£19+vat
OLD STYLE HOUSING ON RIGHT
THIS IS THE OLD STYLE FOAM TYPE BREATHER POOR DESIGN CLOGS EASY
if you can change the air filter you can do this your self it sits next to it
also recommend using Castrol Edge Turbo Diesel 5W40 Oil and changing every 12k or every mot for extended turbo life
i have a couple of x5,s i service with 130k+ still going strong on original turbos & one is mapped <!-- s:thumbsup: -->:thumbsup:<!-- s:thumbsup: -->
Hi, sorry for bumping very old thread, but I have a 2002 e53 3.0d, so is it the 1st part no i need? - part no--modded Breather assembly----- 11127799225 --£40+vat
also whats the price /part no of the air filter please.
Thanks.
Black BMW E70 35D
Previous:
: Tuned Black E53 3.0D Sport
: Tuned and custom E46 facelift BMW 330ci clubsport in estroil blue
Jamee
Post by Jamee » Sat Mar 30, 2013 8:02 pm
Anyone?????
Black BMW E70 35D
Previous:
Sanj
Post by Sanj » Sat Mar 30, 2013 11:28 pm
I know the part numbers but not to hand til Monday. Rule of thumb, preface lift get old sponge-type breather, MOST facelift 05 onwards get vortex type (redesigned and what u want).
Breather will be two halves and old type will not accept new top vortex half only, hence requiring the whole Assembly.
Try to get you those bits after the Easter break, otherwise drop me a nudge.
storminmike
Post by storminmike » Sun Mar 31, 2013 9:13 pm
[quote="Jamee"]
Anyone?????
You'll never know until you delve into the engine. Mine was 54 plate and had the sponge. The wifes is an 05 and had the sponge. Both were facelifts
modded Breather assembly full kit is 11127799225
if (by lucky chance) your is already that type then the insert is 11127799366 I believe
To find out you will have the car literally in bits and in reality a non-driver unless you want to spend half an hour at least putting it back together again. Pulling it apart is a right PITA, doing it twice is madness.
1) pull it apart and drive in another car to dealer (if they have it in stock!!!!)
2) just by the full 11127799225
3) buy both parts (11127799225 and 11127799366) and pre-organise a return if possible
I went for option 2....plenty of coffee and a garden lawn full of plastic pieces
Aevans
Post by Aevans » Thu May 01, 2014 12:41 pm
All,
Having read some really good stuff on here about how to change the breather assembly and air filter I've decided to give it a go, but got a bit of a shock when getting parts prices from BMW.
Air filter £48 inc VAT
Full breather assembly - 11127799225 - £61 Inc VAT
Breather filter - 11127799366 - £32 Inc VAT
Read back through this thread people have quoted less so i wanted to check if these prices sound reasonable or if my local stealer if living up to their reputation ;-)
Denis O
Post by Denis O » Thu May 01, 2014 12:49 pm
Because this is such an old thread then the prices quoted are also...old. When I changed my 04 to vortex I recall the price was just under £50 for the whole assembly.
Air filter can be bought from ECP for between £15 and £30 dependent upon brand.
http://www.eurocarparts.com/air-filter
05 Mercedes SL350
babylon x5
Post by babylon x5 » Thu May 01, 2014 1:26 pm
[quote="storminmike"]
Hi,
Guilty of madness - I have just done mine twice.
I have recently changed the air filter myself before the garage did the oils (engine/brake/PAS) but checked what type I had for the breather.  I got the filter off the internet for a tenner and once the oil was done I took it apart again.
Its easier the 2nd time and eventually should be able to do it blindfold, Rambo style.  :bandana:
Anyway, I only lost one nut and an extra long ball-ended 5mm Allen key which reached the back left one for the cover.
Biggest pain for me was the bolt underneath the windscreen wiper motor, I have left it out the 2nd time.
I replaced the missing 13mm nut with a wing nut (8mm stud) which anchors the pollen filter housing.
The filters I bought were the cheapo ones and don't necessarily recommend the Pollen filter (£15) one especially.  It was far and away more inferior than the BMW one I took out.  Not even sure if it has pollen catching attributes ?
B X5
Babylon X5   :policeman:
Post by X5Sport » Thu May 01, 2014 1:54 pm
That nut is a pain, but I used a flexible wrench from Halfrauds which enabled me to get the @%*+}# thing out.
Sanj
Post by Sanj » Thu May 01, 2014 5:41 pm
That nut is a pain
No way to talk about 535dboy like that!
Post by X5Sport » Thu May 01, 2014 6:09 pm
:)) :)) :)) :)).  :spiteful: :naughty:
Sanj
Re: New 2 bmw
Post by Sanj » Thu May 01, 2014 6:40 pm
He called me short in another thread!
Aevans
Post by Aevans » Thu May 01, 2014 7:13 pm
Fair point regarding the age of the thread, i guess that’s inflation for you.
My motor was built in Feb 05 so its unclear as to whether it has the new or old style breather so i thought i'd remove a few bits under the bonnet in order to try and see a part number. (I cant take it off fully to check as i don't have the fancy female shaped torx tool yet)
Stamped on the part are two sets of digits...
PA 66 GF25 M15
1928 403 998
Sadly nigher of these meant anything to the chap in the parts dept of my local dealer.
Looks like i'll just buy the full assembly so at least i know its the up to date part and sorted. I don't have a second car so popping back to BMW once its off i'snt really an option. (not to mention they don't keep any of the related items in stock)
babylon x5
Post by babylon x5 » Thu May 01, 2014 8:26 pm
[quote="Aevans"]
I presume you are talking about the screws that hold the 'cable run' to get to the air breather assembly ?
If that's what it is, a 5mm socket takes care of it nicely.  ;)
B X5
storminmike
Post by storminmike » Thu May 01, 2014 9:03 pm
[quote="babylon x5"]
[quote="Aevans"]
B X5
Seconded
andym3
Post by andym3 » Thu May 01, 2014 10:24 pm
[quote="Aevans"]
All,
Nice one give it go! It's not that hard really, I done mine last month & took me about 30mins!
I personally don't buy my parts from BMW as you can get the same part for a fraction of the cost at a motor factors!
Let us know how you get on ;-)
