Worn rear bush symptoms
Re: Worn rear bush symptoms
I paid £140 for Mids VW to cut the old bolts to get the swing arm out and fit the secondhand set I got plus fit the new rear suspension and antiroll bar too as they were having to remove the old springs etc anyway.
That seems like a pretty good price- thank for that
I spoke to Quarry yesterday, they have swing arms for £75, so I'll get a pair bought and book it in.
I'm just hoping that sorts it- I think there's still one other link that could be causing the problem (have had the top arms done)?
[quote="RRH"]
Apart from the top 2 arms and the lower swing arm there is only the ball joint itself.
Oh and Mids VW price was a slightly discounted mates rates price but hopefully not too far off.
I'll get everything checked while it's apart- will end up with a brand new car at this rate!
Finally got the job done by AutoTec in Liverpool, £85 a side. Was quite pleased with that!
It feels a lot better overall but it hasnt cured the slight side-to-side shimmy going over bumps.
Any ideas?
They also noted it needs both thrust arms and a front suspension arm too... the list goes on.
Any ideas?
Subframe bushes I suspect, cured ours with the same symptom.but it hasnt cured the slight side-to-side shimmy going over bumps.
Was it an expensive job?
This can be a hard job without the correct tool...
The bushes I used, (Meyle HD from ebay ~£75 for the set.) Me and a mate did the job at another friends garage on a ramp in 4 hours with the bush tool. Would be quicker if I did it again.
Ok, will ask autotec how much and add it to the list!
Its transformed ours and they didn't look that bad before we started but the front two were shot. I also changed the anti-roll bar drop links at the same time as they weren't much money and definitely past there best.
