If you guys have not seen this, take a look, it might help. My CD changer has been dormant for over a year now due to the "NO DISC". Got the grease today and will give it a go over the weekend.
Will let you know the outcome
http://youtu.be/Mk5LWzY9BSg
CD changer fix
CD changer fix
BMW X5 4.6iS V8 SPORT
![Image](http://i819.photobucket.com/albums/zz117/larnaca1/418f1a14-b077-4a1b-9902-cb14668433bc.jpg)
Re: CD changer fix
Worked a treat ![Smile :)](./images/smilies/original.gif)
There was so much dried up grease, took an age to loosen the cogs and clean and re apply the grease, Happy days.
All is needed now is to change all 4 tyre sensors and I'm done.
Re: CD changer fix
I have this issue in my X, was it easy enough to get the top off the changer to get access?
Cheers,
John
Cheers,
John
02 X5 3.0D Sport
Re: CD changer fix
This has just happened to mine! Will give this a try too.
Sent from my GT-I9300 using Tapatalk
Re: CD changer fix
The secret is to just take your time. One word of warning though, be carful when taking off the small box at the back as this is were the ribbon cable is and is so flimsy
Hope this helps guys
Re: CD changer fix
I removed my changer today, unplugged it then re-plugged it, working fine so far, but I expect it will revert back to original problem, thanks for the advice ![Smile :)](./images/smilies/original.gif)
02 X5 3.0D Sport
