Diesel fuel filter
andym3
Diesel fuel filter
Has anyone on here changed a x5 diesel fuel filter? If so can you do some DIY instructions please?
CURRENT CARS - E53 X5 3.0d & E30 325I CONVERTIBLE
- Sim0x
- Contact:
andym3
Re: Diesel fuel filter
[quote="Sim0x"]
You could try following this one:
http://www.bmwland.co.uk/forums/viewtopic.php?t=104151
Thanks!
Didn't realise how much of a pain this seems to be to change! Ok will have to allow myself a good few hours I recon!
Thanks!
andym3
Noticed this when doing the levels on my X5 today. Isn't it the diesel fuel filter?
andym3
Yes my engine bay needs a good clean! lol
- fenj66
i think the pre-facelift diesels had the fuel filter near the webasto heater in the engine bay,
facelift models had it moved to under the plastic tray under the passenger side of car.
- babylon x5
[quote="andym3"]
That's the one -dead easy, did my own a few weeks ago. You may have the crimps on the pipes which have to be cut off, but just need a couple of small jubilees to put them back.
Top Tip - write the date and mileage on the side of the can with a felt tip pen before you fit it - just for the record.
B X5
B X5
Babylon X5 :policeman:
andym3
Brilliant!
Once filter has been changed does it need bleeding etc? If so how is this done? :-[
- babylon x5
[quote="andym3"]
Brilliant!
I had air in the see-thru pipe (nearest in picture) but it cleared immediately when it was started up.
I also topped up the new one with diesel when I fitted it.
B X5
Brilliant!
B X5
andym3
How do you top up the new one? :-[
- babylon x5
[quote="andym3"]
You can clamp it in place and have a small funnel in the centre hole
B X5
B X5
andym3
Did you use the diesel from the old filter? :-[
- babylon x5
[quote="andym3"]
No, I wasn't sure which was the 'dirty' side so used a can of new stuff.
I have a can of dirty diesel for cleaning so drained the old one in there.,
One or two of the 'old codgers', I mean experts, on here might be able to enlighten us as to whether that practice is Ok or not.
B X5
B X5
AFAIK the system is self bleeding. It does sometimes need a couple of starts to fully clear the air out though.
andym3
Excellent just what I wanted to hear! The X5 has had in the past couple months gearbox oil & filter changed, engine oil & filter changed, also the airfilter and camshaft breather filter. So the fuel filter is the last filter to be changed!
