Hang on back Bike Rack
dark_stranger
Post by dark_stranger » Tue May 06, 2014 12:21 pm
Can anyone recommend or advise to avoid a hang on back type bike rack?
Smeeagain
Re: Hang on back Bike Rack
Post by Smeeagain » Tue May 06, 2014 1:25 pm
I got one from micksgarage.com - it was easy to identify from their site as to which was the correct one but I called to check and they were really friendly/helpful. I got it then couldn't quite follow the instructions (just me being dim) and they talked me through it - they also have videos to show you how to assemble/attach
IT was around £60 (last year) and held two bikes no problem at all
I don't know then and I'm not connected to them commercially or otherwise just to be clear
jaynana
Post by jaynana » Tue May 06, 2014 8:38 pm
[quote="dark_stranger"]
avoid (if i got ur question right)
hanging staps put downward load on the spoiler and that's a piece of plastic , cannot open without removing the bikes, potential for damaging the paintwork and/or the bikes.
tow bar and a tow-bar mounted bike rack - my kind of solution.
sid10
Post by sid10 » Tue May 06, 2014 9:52 pm
I think BMW did a hang on bike rack that fixed to the roof rails which are supposed to be very good !
I have the hydraulic bike lifts that fit onto the roof bars which makes it easy to get the bikes onto the roof .
Smeeagain
Post by Smeeagain » Wed May 07, 2014 8:58 am
The one I mentioned from mickgarages can be opened without removing the bikes (although with two or more bikes there is a lot of weight on the tailgate as it comes up and its best to hand someone holding it (or go in through the side door for whatever you forgot you need!! 6 P's spring to mind .....  :)))
They come with large rubber blocks to protect the paintwork, but I got some of the foam they use to lag pipes and put around scaffolding to give added protection or protruding metal parts such as pedals (better still remove the pedals). If you only have one bike on it then you put it rearmost and it is nowhere near the paintwork (as there is room for another bike between it and the car)
Ultimately it is your choice - but to the point of damage you have as much risk damaging your paintwork hanging something off the back as you do with same roof bars and scratching the paint as you life the bike up and down.
And of course budget comes into it to. For example a two bar solution requires a tow bar - and if you don't have one already (and particularly if you don't plan to use it/the bike rack a lot) then it is a lot of extra cash over the £60 rack
Horses for courses really.
dark_stranger
Post by dark_stranger » Wed May 07, 2014 12:32 pm
Cheers Guys & Girls, need the towbar to pull the trailer/motocross bike.  Dont want roof mounted as have to avoid low barriers, etc.
Was looking at the one on Mikes Garage and looks very similar to the multi fit one I have stored in the shed for an old car.  Might see if I can fit that on the X5.
scratchpole
Post by scratchpole » Fri May 09, 2014 4:01 pm
Have you considered a flange mount type? Witter is one company who make these. The mount is fitted between the tow bar and the bolt on ball so that you can still tow a trailer with the bikes on the rack.
The rack is fitted to and removed quickly from the mounting bracket. I would have preferred this type but as the car came with a swan neck tow ball I had to go for the ball mounted type.
Scratchpole
E53 X5 3.0i Auto 2003
Previous BMWs
E3 2500 Auto
E36 3-Series 2.5i Coupe Manual
E34 5-Series 2.5 Saloon Auto
dark_stranger
Post by dark_stranger » Mon May 12, 2014 12:55 pm
[quote="scratchpole"]
My towbar is also a swanneck  also.  There are some systems that can hook onto swanneck towbars, but dont have much faith in them.
