isolate head unit
Colin
isolate head unit
What fuse and where is it , the one to isolate the head unit as i dont want another flat battery at 4:30 am , the battery has been on charge all day .. thanks.. Colin ..
05 , 30d Le Mans Blue Sport
Re: isolate head unit
Front fuse card. Looks like Fuse 7?
Colin
thanks for that Richard, And thankyou for the answer to my earlier question about the flat battery , only problem i see is it also isolates the phone .... ah well..
- Steamyrotter
Pull the fuse out..
Then temporarily plug in a switch with inline fuse, in place of the fuse.
Normal spade terminals should fit in there..
That way you can turn it back on when you have the car started and have the phone, but know the "issue" will not drain your battery until you can fix it properly....
Please note...
Please note...
