Rear suspension inactive / tyre deflation light on
CondorX5
Post by CondorX5 » Thu Mar 20, 2014 1:46 pm
This old chestnut popped up again after a period of happy trouble free driving for the past 18 months in this respect - its a "hard fault" and appears instantly the ignition is switched on and always with the tyre deflation light on as well, which will not reset in the normal way.    Am assuming it is either a sensor or possibly the boots have a split or the compressor is not working for some reason?
Have checked tyre pressures etc and all is well.  Tired of driving around in a boneshaker now and will have to get it booked in, its still on extended warranty so hopefully that will cover most if not all unless its split boots which is invariably wear and tear.......
Anything else I should check before booking it into dealers?
X5 2005 Le Mans Blue 4.8is
Re: Rear suspension inactive / tyre deflation light on
Post by X5Sport » Thu Mar 20, 2014 2:27 pm
Tyre pressure sensor failure?  Have you got the ones on the tyre valves themselves?  I believe some had little radio transmitters rather than the ABS wheel speed checking option.
CondorX5
Post by CondorX5 » Wed Mar 26, 2014 10:39 pm
No, mine are the rolling radius / ABS type. Those ones with batteries in were on the 4.6is I believe.  It was absolutely fine, switched off and when I came to start it next morning the fault popped up - tyre deflation light comes on instantly with the self levelling suspension inactive message.  No time to book it in yet.
Raj
Post by Raj » Wed Mar 26, 2014 10:56 pm
Is all the suspension looking ok as in all sat at the right height etc?
Is so may be the control module is playing up hence both errors appearing. Otherwise just a sensor playing up somewhere.
Does seem more electrical issue.
CondorX5
Post by CondorX5 » Thu Mar 27, 2014 10:07 pm
I thought it was sitting square but when I looked at it parked up I thought it was sitting a bit skew when viewed from the front. Must get it booked in somewhere, driving it is not fun with suspension inactive!
pvr
Post by pvr » Thu Mar 27, 2014 10:19 pm
You seemed to have made the right decision on the warranty ...
911 50th anniversary -
CondorX5
Post by CondorX5 » Sat Mar 29, 2014 7:46 am
Haha yes i was wondering when the box would go pop, the pano roof stick open and the suspension compressor give up.
