New Owner of E70 X5
Keithe46
New Owner of E70 X5
Post by Keithe46 » Wed Mar 05, 2014 1:56 pm
Afternoon folks
Just joined up so thought I would say hello. I had my first X car delivered to at the weekend and loving it so far. It's a 09 30d. Came from a E46 M3 so it's completely different but really like it.
I have a few questions so far. I have a rear tow bar that I will never use, is it easy enough to remove?? Also I have tried to play music from my iPod/iPhone through a aux cable however there is a buzzing sound, does anyone have any suggestions as to why, or how to sort it?
Cheers in advance!!!!!
Don Coffey
Re: New Owner of E70 X5
Post by Don Coffey » Wed Mar 05, 2014 2:08 pm
Welcome, just need to see the photos now.  Is the Towbar not of the removable type?  These are the most common on the X.  If it is a fixed Towbar, I don't think that would be hard to remove, the issue would be if a hole has been made in the bumper.
Don
Raj
Post by Raj » Wed Mar 05, 2014 5:33 pm
Congrats and welcome.
Tow bar should be an easy removal job tbh. As for the buzzing, that I suspect would be down to the connection not being quite right. Just to eliminate try a different device using the exact same wire and method. Then try a different wire that way you've discounted the phone/iPod and the cable itself. It's just a process of elimination as you need to work out if it's on the car connection as then you can get BM to look at it under the warranty if it's a dealer car.
Keithe46
Post by Keithe46 » Thu Mar 06, 2014 9:05 am
Hi guys,thanks very much for the replys. I will get under the car today and get a look at the tow bar.
Also thanks for the advice on the aux cable, done a bit of research on google and ordered another cable.
Cheers again guys!!!
Pope
Post by Pope » Thu Mar 06, 2014 10:42 am
Welcome and enjoy your new Xbox Keithe... :)
I'm sure you wont miss your M3
:pope:
Garage:
BMW X6 40d Pink
Ducati Diavel 1198 Carbon
Post by X5Sport » Thu Mar 06, 2014 10:43 am
Welcome to the club..... :hi:
Keithe46
Post by Keithe46 » Fri Mar 07, 2014 12:29 pm
Cheers again for the replies gents!!!
Just spoke to a local tow bar company who have quoted 3 hrs work (£120) to remove the tow bar, does this sound right??
Cheers!!!!-
Pope
Post by Pope » Fri Mar 07, 2014 1:11 pm
[quote="Keithe46"]
Cheers!!!!-
So, its not the OEM quick release one then....
3 hours to remove a fixed towbar sounds a bit steep though......id be inclined to get another quote.
:pope:
Garage:
BMW X6 40d Pink
Post by X5Sport » Fri Mar 07, 2014 1:33 pm
If it's a factory one you will also need the car recoded to remove it from the systems.  They aren't plug & play like the E53 version is.  If it's an aftermarket towbar then that may not be an issue.
The standard fit one is a swan neck and the towball just detaches once the key is in the towbar lock.  You just turn a handle.
Don Coffey
Post by Don Coffey » Fri Mar 07, 2014 2:08 pm
It might be worth taking a photo of the Towbar from underneath to let us see what type you have fitted.
Don
