bmw 1 4 0 scanner not working
maci234
tried to get this going as few times and still nothing it keeps saying drivers not installed, trying to install on windows vista I,m sure someone knows an easy way to get it working hopefully thank you
bmw x5 3.0 diesel 2005
- Dessie
Re: bmw 1 4 0 scanner not working
Common problem with this, I had the same and fixed it using http://forum.e46fanatics.com/showthread.php?t=942966 although I m using windows 7. Good luck :'(
2004 3.0d Sport, Sterling Grey with 19" Gunmetal Grey wheels. Pano Roof and full colour coding.
- Steamyrotter
The first thing you need to do is ensure the interface is plugged into the car before you load the drivers..
The PC wont see the interface, in order to load its drivers, unless it has power..
The electronics in a lot of the scanner units are powered from the car and not the PC.
Please note...
Please note...
