Winter Tyres & Rims
x555
Re: Winter Tyres & Rims
Post by x555 » Fri Nov 26, 2010 7:40 am
Just checked ny oem sizes with that tyre size calculator link and they were saying 0.2% difference in circumference and saying 4.8mm diference in circumference.
Don't know how much difference it makes but the e53's are all wheel drive not permanent(i think more goes to the rears) i'm not sure on the e70's mind as haven't had one yet :cry:
Post by X5Sport » Fri Nov 26, 2010 9:57 pm
Should that not be a 315/35 R20 to avoid the circumference change?
Given the difference in rolling diamater is there a risk of shattering the 4wd drive system due to the rotation speed differences between front and rear axles? No idea how big an issue this is as I don't know how the X-drive sorts out the possible torsional load variations across the 4WD system.
bullethead
Post by bullethead » Fri Nov 26, 2010 10:10 pm
only mm's in it.
flyfs6
Post by flyfs6 » Fri Nov 26, 2010 10:15 pm
A few people over in the States are using the 295/40/20 without issues. As correctly pointed out it does put the speedo out by 2% (an acceptable limit in most conversion guides), but given 315/35/20 are difficult to get hold of, it is just one of the possible options.
Whatever you do don't go for 295/45/20 as that will give you a 5% increase in speed relative to speedo and 295/35/20 will put the speedo out massively too.
There is pretty much only one winter tyre for 315/35/20... by Pirelli, called the Ice & Snow Scorpion Runflat winter tyre - about £450 each.
In the 295/40/20 size, there's more to choose from, and at lower cost too.
Pirelli Ice & Snow Scorpion (non-RFT) - £285 approx
Goodyear UltraGrip - £290 approx
Dunlop SP Winter Sport M3 - £290 approx
Continental ContiCrossContact Winter - £295 approx
There's also an alternative size of 305/35/20 but availability is limited to the Pirelli W240 Sottozero, which is mega expensive at about £450 each
Avtar
Post by Avtar » Sat Nov 27, 2010 9:33 am
Am in the process of ordering Pirelli Scorpions ICE & SNOW Run Flats:
25550/10 - £241.20
285/45/10 - £262.20
Current Drives:
Alpina D5 BiTurbo
E70 3.0sD SE (Sold)
E46 330 Convertible
Alpina B3 S BiTurbo (SOLD)
History:
E39 528 Sport, 530 Sport
E38 735 Sport
E36 318iS, 320, 325
Avtar
Post by Avtar » Sun Nov 28, 2010 11:02 am
Guys, am I right in understanding that as long as the load rating is the same it should not matter if they are run flats or not, as I am considering not getting the run flats to assess the difference in ride quality?
Also would coming off the run flats have any implications for the warranty or insurance?
Current Drives:
Alpina D5 BiTurbo
E70 3.0sD SE (Sold)
E46 330 Convertible
History:
E38 735 Sport
E36 318iS, 320, 325
shocks
Post by shocks » Mon Nov 29, 2010 8:03 pm
With the snow thick on the ground up here in scotland (worst I've seen since a sprog) the x is coping reasonably well - i'm on 20" and thinking about the BMW offer, local deal has this :
http://www.easternbmw.co.uk/parts/own.html?id=8310
Scroll down to the X5 section, wondering what would be best setup as mine is the 4.0d M Sport - thinking 18"s would be best all round but may not look right with the msport setup and thus 19's are way to go, thoughts ?
Aside from the other suggestions of sourcing the rubber at 265 per corner = £1060 + rims + fitting the BMW offer can't be that far off a DIY approach ?
Current
Macan GTS
M135, the commuter
991 GT3 - The Toy III
History
E39 520 - family lugger
E53 4.4 Sport
E70-FL 4.0d M-Sport; Lots of toys
996 Turbo - The Toy
991 Cab S - The Toy II
numerous others...
Avtar
Post by Avtar » Wed Dec 01, 2010 1:29 pm
Working in Telford at present, the main roads are fine but I had to travel about 300 yds down a country lane to the hotel.....not easy on 20" rims with low profiles.
Current Drives:
Alpina D5 BiTurbo
E70 3.0sD SE (Sold)
E46 330 Convertible
History:
E38 735 Sport
E36 318iS, 320, 325
bullethead
Post by bullethead » Wed Dec 01, 2010 5:02 pm
Sort of relevant and not, tried getting 4 for er indoors car, and everywhere inc. the net were sorry no chance. Just got 4 from Germany £125 delivered.
Ordered Friday, just delivered about 20 mins ago. Now just got to get them fitted. Note I said "I'll have to get them fitted". even though its her bloody car ;)
Avtar
Post by Avtar » Wed Dec 01, 2010 5:41 pm
[quote=""bullethead""]Sort of relevant and not, tried getting 4 for er indoors car, and everywhere inc. the net were sorry no chance. Just got 4 from Germany £125 delivered.
Ordered Friday, just delivered about 20 mins ago. Now just got to get them fitted. Note I said "I'll have to get them fitted". even though its her bloody car ;)[/quote]
Mate, that is a given, they are not gonna get around to it themselves. At least they feed and water us.
Mine will hopefully arrive by the weekend or early next week and knowing my luck the rest of the winter will be a mild one.......
Current Drives:
Alpina D5 BiTurbo
E70 3.0sD SE (Sold)
E46 330 Convertible
History:
E38 735 Sport
E36 318iS, 320, 325
shocks
Post by shocks » Sun Dec 19, 2010 1:59 pm
Ok so seeing as the conditions aren't getting any better up here I've been back to the search for winters; coming up blank and then found this :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _511wt_907
Any thoughts on these ?
Will they fit the M-Sport ?
Also Been bidding on E70 alloys on fleacebay - just missed out on a full set of 213's (19s) which went for £361; though now going to ditch this approach as can't get Winter tyres from Blackcircles, mytyres or any other of the usual sources !!
Help and advice on above link appreciated !
Current
Macan GTS
M135, the commuter
History
E53 4.4 Sport
996 Turbo - The Toy
numerous others...
MaXX99
Post by MaXX99 » Sun Dec 19, 2010 3:27 pm
Have a look on www.salesafter.eu
They have them in stock ...
Avtar
Post by Avtar » Sun Dec 19, 2010 4:05 pm
[quote=""shocks""]Ok so seeing as the conditions aren't getting any better up here I've been back to the search for winters; coming up blank and then found this :
Help and advice on above link appreciated ![/quote]
Blackcircles are good but when I enquired they did not have any run flats in stock at the required sizes, this may have changed. If you have an alternative to mytres.co.uk I would use it (check my post in the forum discussion section under mytyres.co.uk) probably the worst customer service ever and rubbish to deal with.
Current Drives:
Alpina D5 BiTurbo
E70 3.0sD SE (Sold)
E46 330 Convertible
History:
E38 735 Sport
E36 318iS, 320, 325
Monkeyman
Post by Monkeyman » Mon Dec 20, 2010 10:58 am
I am looking at putting the following on my e70 for the winter months.......currently on 20's with 315 at the back and I think 285 at the front.....looking at buying a complete set of 18's with Bridgestone Blizzak's on.....
Was wondering as I am running a 20 shod sport whether or not there would be any problem putting 18's on with the same size all the way round
Previous
E30 325i 2 door
E36 323i Coupe
Volvo T4........God knows why....but damm quick
E60 530d M Sport
E70 3.0sd SE Space Grey
Current
E70 3.0sd M Sport Carbon Black
MaXX99
Post by MaXX99 » Mon Dec 20, 2010 11:01 am
I come from the same staggered setup : 275/40R20 & 315/35R20 and am now running on 4 255/55R19 as recommended by BMW.
It does look a bit odd on the rear where it is a bit empty compared to the 315 ... but otherwise it is a perfect combo ...
I have heard from people putting spacers in place for the looks ... but then again you loose all warranty etc ...
