Thermostat ,is it the problem ? ( FIXED )
Colin
Re: Thermostat ,is it the problem ?
Yes the main one , and the sooner i get it the better because my mpg is suffering as much as 4 mpg !...
05 , 30d Le Mans Blue Sport
- jaynana
that is very unusually low.
as said i have this temperature issue, car does school runs most days, mpg is around 19!
i know there's no prob because on motorways i get about 33 - 34mpg.
- jaynana
[quote="storminmike"]
If all the above tests fail keep a look out for the auxillary pump
Mine wouldn't go above the first tick even after the main stat had been replaced. The heat in the cabin was bobbins too
Turns out it was the aux (electrical) pump which IIRC is next to the rad on the smaller pipes going to the Webasto and Cabin
Car dead centre and cabin nice and toasty....
54 plate X5 Facelift 3.0d
ps mine was without an EGR thermostat based on the year....and I looked as well...and there was none
Look here
Picture of EGR thermostat....but on my car...No parts found matching your car.
http://www.realoem.com/bmw/showparts.do ... g=11&fg=50
Whereas this shows the setup WTHOUT EGR
thanks for that, mine's also without thermostat.. (the bronze coloured pipe is the EGR jobbie)
btw i tried to do the replacement and went half way - the blo0dy thermostat screws need a female torx set!!! >:D had to give up for now! and ordered a female torx set!
another issue is the EGR valve can be fused to the exhaust manifold due to extreme heat. how do i take that off?
Look here
storminmike
[quote="jaynana"]
Look here
That looks just like my car....No EGR thermostat...just a link pipe
But...and I confess....my indy did the main thermostat....and later the aux pump
He may have left that link pipe alone to get at the main thermostat underneath?
Look here
Colin
Same as mine too , that link pipe has to come off for ease of access to stat which is just below , you can see the bottom hose connected to it , not easy got at with big hands . OH and dont drop anything . lol
- Caesium
That pic is strange to me.
I've had four different model cars with the six pot diesel, and none of them had that set up!
Currently :
2013 BMW E70 X5 40D MSport
Previously :
2008 BMW E92 335D MSport
2004 BMW E46 M3
2005 BMW E60 535D MSport
2002 BMW E39 530D Sport
The list goes on...
Previously :
2004 BMW E46 M3
The list goes on...
Colin
This is my first BMW diesel mines sept 05 E53 , id thought these diesels were well used across the range .
- jaynana
[quote="COLIN"]
Any suggestions on how to remove it off the exhaust manifold. Just 2 Allen screws but pretty sure it's fused due to extreme heat!
Colin
I must admit it wasnt me who took it of BUT i was watching and holding the torch ( v important job ) allen or hex im not sure but just seemed to come of no bother , getting the four bolts of the stat were tricky to get at , i could hear mumbling and some bad words used, then all hell broke loose when he droped a bolt down the front of the engine ,THEN the shit hit the fan when he discovered he had been sent the WRONG stat and had to put it all back together, will get correct stat on monday , up side is at least he got a practice run at it , lol
Colin
UPDATE ON STAT , booked the X in tomorrow morning (saturday ) for new stat install , hope it makes a difference , ...
Colin
Re: Thermostat ,is it the problem ? ( FIXED )
New stat installed and working great , temp needle straight up at twelve position in no time , thinking back the needle never went up there from i bought it so must always been faulty , great heat now ..
storminmike
[quote="COLIN"]
EXCELLENT
EXCELLENT
Colin
My MPG is now back up to 32 on the OBD it had dropped to 28, and drives much better , gear change smoother , and probably a lot of other things we dont know about , i love the extra heat , lol
Below the correct operating temp the car stays in 'cold' program mode so it will be much smoother now. Glad it's sorted, and if the weather forecast is anything to go by just in time too.... :cold:
Colin
Yes weather taking a cold turn , im looking forward to getting the remote start fitted for the webasto ,soon i hope ,, Richard do you have a webasto on the E71 .. Colin
