Front discs and pads
Johnny-p
Post by Johnny-p » Fri Nov 08, 2013 8:53 pm
Hi all
After having my X for four months now I am well chuffed with it..
I bought it a bit cheap so was expecting a few trips to the Indy!!!
As has been said in my previous posts I have had a few bits done to it to get rid of an annoying vibration that was there when I bought it..
I put on a full set of new rubber/ laser alignment/front bushes and this SEEMED to have cured it.
HOWEVER I towed my caravan last week and my senses are always a bit heightened when doing this and it didn't seem right.
Took it to the Indy today and he gave it a good thrashing on a test drive  >:(
Turns out I have a warped f/n/s disc that's causing the remaining vibration...
Anyhoo I'm waffling so the question I'm asking is....
He's quoted me £298 for new pads and discs fitted..
Does that sound right??
I can buy them myself for a little over £100..
Is it a specialist job or could I take it to my local mechanic without problems as he would only charge an hours labour?
I've spent a lot so far and the coffers are getting sparse..
He also said the gearbox was running a bit slow and said an engine and box software upgrade would sort that for £50.
Fingers crossed that's the last of it for a while as on top of all this I had the breather/oil separater brake pipes and fluid change.
I don't think I could bare driving at car height again!!
2005 X5 3.0d Sport-Black sapphire-cream leather-pan roof-folding mirrors-sliding boot floor-soft close tailgate-heated F/R seats-F+R air con-rear blinds-Bluetooth/voice recognition-satnav/tv in-motion-aux enabled-headrest monitors/DVD-aux heating-alarm chirp-chrome dials-detachable towbar  ;)
shadrack
Re: Front discs and pads
Post by shadrack » Fri Nov 08, 2013 10:08 pm
Front discs are a piece of piss to do. Diy them and save even more!
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Post by X5Sport » Fri Nov 08, 2013 10:17 pm
Defo DIY job.  Wheel off, remove pads (you'll be fitting new ones anyway), caliper and one screw and that's it I think.  You might even get away with leaving the caliper in place.  Or you source the parts and he fits.
Gearbox "running a bit slow"!  What on earth is that supposed to mean?  Is there a fault code showing?
Johnny-p
Post by Johnny-p » Fri Nov 08, 2013 10:32 pm
Sorry reading it back it does sound a bit thick!!
What he was referring to was the delay in throttle response/gearbox reaction..
He said a lot more but I'm afraid most went over my head :-[
Had it hooked up for diagnostic when I first bought it as the alarm kept going off- bonnet switch. No other codes found..
Post by X5Sport » Fri Nov 08, 2013 10:41 pm
Ahh......There certainly have been firmware updates for the transmission.  Whether they were to improve response times I don't know.  Most of the comments I've seen referred to the dreaded 'lurch'.
R
Johnny-p
Post by Johnny-p » Fri Nov 08, 2013 10:49 pm
Nah he said all seems good with the box/diffs etc ..
Had me a bit fuming at the time as he gave it a good thrashing(I do drive it like a girl tho to be honest)!!!  >:(
Raj
Post by Raj » Fri Nov 08, 2013 10:53 pm
You will need to remove calliper to change discs but still not difficult. It's just a few bolts etc and very straight forward. Deffo diy or local mechanic job for sure.
mikem
Post by mikem » Fri Nov 08, 2013 11:45 pm
Discs/pads are a diddle on the front but if your local mechanic will do it for say £40-50 cash it's not really worth getting dirty for especially in this weather.
I'm not convinced a 2005 would need a software update on the gearbox. Our 2006 has the same software loaded as a friends 2005 and both are dated from the factory the main dealer has also confirmed it's the latest available.
Denis O
Post by Denis O » Sat Nov 09, 2013 5:35 am
Surely the box just needs the driver learning reset. From memory it's foot flat on accelerator, turn on ignition, hold for 30 seconds and the adaptive settings return to normal. It'll then learn your driving style over a few miles. Best google and check process but I'm pretty sure thats the way.
PayPal me £35. Much cheaper than your indy at £50.  ;)
05 Mercedes SL350
Johnny-p
Post by Johnny-p » Sat Nov 09, 2013 10:25 am
Thanks for all the replies-very helpfull
Will try the box reset and see how I get on.
Like I said I do drive it very sedately and the previous owner may have been lead footed..
I may give changing pads n discs a go myself seeing as there are no complicated procedures to trip me up and leave me with a dashboard of error messages!!!
Johnny-p
Post by Johnny-p » Mon Nov 11, 2013 10:25 am
Update
Reset the box yesterday as per instructions suggested..
I've been out on a couple of short trips but couldn't notice much difference,however on the daily commute to work this morning 25mls- what a difference!!!
The changes seem smoother and more importantly seem to occur in the right rev range for my girlie driving style! :-[
Will note mpg now as that may improve slightly...
Thanks all for the advice
Top forum!!!
Post by X5Sport » Mon Nov 11, 2013 10:28 am
The adaption procedure takes a few days to 'relearn' your style, so it should improve going forward.  :)
sonny007
Post by sonny007 » Fri Nov 15, 2013 11:23 pm
[quote="Johnny-p"]
Hi all
Dude, whats the mileage on your x5?
E53 2005 3.0d Sterling Grey, 20 Inch V Spoke, SatNav, Exclusive Black Leather Comfort Heated f/r Seats, Heated steering wheel, Power folding side mirrors, Panoramic Sunroof, Auxiliary heater, Xenons, Climate Windscreen Parrot MKi9200
