Window lift repair ?
Frontman
Post by Frontman » Mon Oct 14, 2013 11:37 pm
Hi folks, I have had a troll through the forum but........
Did I see a repair kit for the front electric window lifter . Not had a look yet but the passenger side window goes down and wedges itself intro the door. It can be persuaded in an emergency bit living in Lancashire it's always a bit of a risk.
I seem to remember a kit or part being available but instead of waisting hours trolling about I'm sure raj or someone will know where to go.
Hey thanks peeps,
col
My Other car's a Hilux Surf.
Smeeagain
Re: Window lift repair ?
Post by Smeeagain » Tue Oct 15, 2013 12:16 am
I'd really like to think you were trawling through the forum rather than trolling  :)
Steamyrotter
Post by Steamyrotter » Tue Oct 15, 2013 1:06 pm
Please note...
Mick.H
Post by Mick.H » Wed Oct 16, 2013 9:40 am
I just did mine recently. Replaced both plastic clips. But it turned out to be the cast iron runner that the cable clips into.  £8 on ebay for a plastic one so might be worth changing that as well as it also seems to be a common fault and an easy fix.
You dont have to remove the airbag btw. Im not sure why people say you do. I just left it in place
Frontman
Post by Frontman » Sun Nov 03, 2013 9:33 pm
Thanks for the link/advice.
