Passenger heated mirror not working
gareth82
Post by gareth82 » Wed Nov 24, 2010 2:13 pm
Hi my heated passanger mirror isnt working, I read the code with BMW scanner 1.4.0
The code I got is
open circuit mirror heating or cable, passenge's door
is this likely to be wiring, fuse or heating element inside the mirror/glass
Many thanks
2001 X5 3.0d sport
AW8
Re: Passenger heated mirror not working
Post by AW8 » Wed Nov 24, 2010 8:46 pm
Why not try connecting your working heated glass to passenger side. obviously glass wont fit in housing but you should be able to check function of heating aspect. Be careful with the connectors they can be fragile - especially when cold.
I have replaced 3 of these mirror glasses so far. 2 leaked chromatic fluid & an ebay replacement refused to heat up (luckily trade seller swapped me out a good one though ).
If buying new glass make sure you get correct part as there are a few different ones depending on spec.
gareth82
Post by gareth82 » Wed Nov 24, 2010 8:48 pm
[quote=""AW8""]Why not try connecting your working heated glass to passenger side. obviously glass wont fit in housing but you should be able to check function of heating aspect. Be careful with the connectors they can be fragile - especially when cold.
I have replaced 3 of these mirror glasses so far. 2 leaked chromatic fluid & an ebay replacement refused to heat up (luckily trade seller swapped me out a good one though ).[/quote]
Dont know why I didnt think of that :roll:
Whats the best way of removing the mirrors so I dont wreck anything?
thanks
2001 X5 3.0d sport
AW8
Post by AW8 » Wed Nov 24, 2010 8:55 pm
.........................I knew that was coming.
You basically angle mirror and push glass to the sky causing it to free from slide in tabs.
I cant recall whether I angled the glass up or down - give me a while to think, fiddle or google ............apologies but dont want you breaking stuff on back of bad advice.
AW8
Post by AW8 » Wed Nov 24, 2010 9:12 pm
I knew it was out there somewhere............found this workshop diagram on another forum. Guide is for an early L322 Mk 3 Full fat Rangie but E532 shares same mirror bits.
Click for link all credit to RRPhil author of post on the other site :thumbsup:
Tip taken from Sanj ;) Be careful not to drop glass if only held by connectors, (maybe use use lengths of masking tape or otherwise be creative).
gareth82
Post by gareth82 » Wed Nov 24, 2010 9:31 pm
Happy days all help is much apprecited will try this tomorrow.
I bought the X5 around 4 weeks ago and a big thanks to this forum for helping me sort out all the wee niggles and problems.
Next on list,
turn off cold check via bmw scanner 1.4.0 to stop LED markers and number plate lights flashing every 30 secs - NOT SURE HOW TO DO THIS YET
2 new rear tyres
instrument cluster (pixel fault)
2 faulty injectors
handbrake and I am sure I will come accross more problems.
I got the X5 at a good price and absolute love driving it so dont mind spending a few pound to get her tip top
2001 X5 3.0d sport
AW8
Post by AW8 » Wed Nov 24, 2010 9:37 pm
I think you can buy leds that wont trip the canbus warning on dash -others will know more I am still on the paraffin bulbs ;)
