How do I change the rear lights??
- Dimsum
Re: How do I change the rear lights??
Bugger....
Went out last night and noticed the brake light LED's are flickering.....
Any thoughts how to get rid of this?
Its very minor but I guess this is a problem...
Sent from my GT-I9300 using Tapatalk 2
- Steamyrotter
Most likely a coding issue on the light Check control.
You couls get away with turning the check off using a scanner.
Think the 4.1 jobbie will do it.
Please note...
Please note...
- Dimsum
Don't mind the odd "check lights" message popping up it the flickering that irritates me.
Can I do anything to get rid of it??
- Steamyrotter
Check control sends a pulse along the lights to check for load.
hence the flashing.
There are hot and cold check modes.
(ie when lights are on, and when off respectively)
You can turn either or both off depending on your preference
I know this can be done with NCS Expert.
I think it can be done with Navcoder & Scanner 4.1
With LED then i think you should be OK to turn both off and be done with it.
hence the flashing.
Please note...
Please note...
- Dimsum
Thanks for that.
Do you know if I can turn off the brake light check but still keep everything else? Indicator light check etc?..
Raj
Just need to add a resistor in line to sort it then no need to code out the check control.
- Dimsum
Thanjs Raj
How would I do that? Sorry for all the dumb Q's but I dont have a clue with electrics..
- Sanj
Yeah Raj, how would you do that?
- lezmtaylor
And fit silvered indicator bulbs.
Lez
Lez
- Steamyrotter
[quote="Dimsum"]
Yes you can
Any option can be selected / unselected for most individual lamps.
As far as i can remember you cnat select left or right number plate lights (But may be wrong on that.
Would need to check.
Resistor method, although would work, can affect currents and brightness if done wrong!!
at end of day the resistor would be generating heat by dissipating the current NOT used by the lights.
A rather in-efficient method.
Yes you can
Please note...
Please note...
- Dimsum
Thanks again guys..
So I can get rid of the warning bing bongs but the fkickering would remain. Its very minor so I dont see a problem with that but would it be an MOT failure??
Raj
[quote="Sanj"]
In line main positive wire. Do the same for the angel eye rings as thy come with then in line too. Tricks the check control to see a standard bulb resistance...
- Steamyrotter
[quote="Dimsum"]
Thanks again guys..
Turning off the check control will stop the flickering also as it will not pulse the supply to see the bulb..
Thanks again guys..
Please note...
Please note...
james8whippy
So I installed the exact same lights at the weekend and to start with the Pins from the loom didn't line up with the connector on the lights. Everything worked except the side lights. I got the multimeter out (Thanks Sanj) and traced the wire and it turned out Pin 1 was the side lights so I had to move that to Pin 4 on the loom plug.
Success Lights all worked............ But the side lights now flicker and I get the "Check Tail Lights" message.
Strange because my Brake lights are absolutely fine whereas Dimsum's flicker....
Steamyrotter - I have Navcoder installed and will turn off the check controls when I get home to see if I can remove the flickering.
Will let you know the results
james8whippy
