[quote="Nat"]
Hi,
Thats some driveway , 700m2.......................
Block paving no issues if foundations done properly and if it sinks you just lift the blocks and pack more sand under it, so very easy to repair.
Weeds can be a problem, regular spraying is the answer.
Make sure the outer bricks/blocks/sets are properly fitted and set as thats what holds the rest in place.
Regards,
Nat.
Cheers Nat, yes, a largish driveway, but seemed like a good idea when the digger was around doing the land scraping....should have just taken the shortest route to the road!
Taken from Apple maps and not great quality, but you get the idea. The photo is a couple of years old, I should really get some fresh ones, especially as I can get my own aerial shots.
Don
