Rear wiper
MAZI
Rear wiper
Post by MAZI » Fri Sep 20, 2013 10:55 am
Rear wiper is not clearing screen.
Newblade makes no difference
Re: Rear wiper
Post by X5Sport » Fri Sep 20, 2013 11:28 am
You could try very gently bending the arm to make better contact with the glass, or the pressure spring may be soft.
Smeeagain
Re: Rear wiper
Post by Smeeagain » Fri Sep 20, 2013 2:58 pm
[quote="MAZI"]
Almost certainly the pivot arms needing cleaned (prevents the arm pressing the blade against the screen properly) - comes up on here regularly - go to Search then type in rear wiper arm, read the posts and you will find the answer you need ...... and unless your blade needed changing anyway then keep the old one as a spare as there probably wasn't anything wrong with it
Willbof
Re: Rear wiper
Post by Willbof » Fri Sep 27, 2013 10:20 pm
WD40 on the pivot
Tidy like
Dimsum
Re: Rear wiper
Post by Dimsum » Fri Sep 27, 2013 11:11 pm
I ended up replacing the whole arm.... seemed easier in the end!
Sent from my GT-I9300 using Tapatalk 2
petert
Re: Rear wiper
Post by petert » Sat Sep 28, 2013 9:35 pm
Lubricating the pivot worked for me and only took a few seconds.
Peter T
