DSP retrofit?
grantsmtih82
DSP retrofit?
Post by grantsmtih82 » Thu Aug 22, 2013 8:06 pm
can this be done in a E53  that has nav/tv/bluetooth?  would prewiring be there for it to be plug in play? or would i need to get / install the correct wiring looms?
X MAN
Re: DSP retrofit?
Post by X MAN » Fri Aug 23, 2013 1:21 pm
[quote="grantsmtih82"]
Yes it can be done . E53 X5`s are not pre wired for DSP and will require the correct wiring harness to be
  installed to acheive this. I also have nav,tv,bluetooth and will be doing this retrofit to mine soon.
05 X5 3.0d
Mods:H/s wheel.F/mirrors.Lumbar.Compass-remote r/v mirror.Rem ctrl.Bins holder.T90 Telestart.20"168's.Arches.Titan grills.Skid plate. P/O load floor.R/seat e/b/rest.R/blinds.H/rear seats.is r/bumper trim.chrome dials.car key mem.intravee.DSP.RV Cam.Dbl glazing.Ski bag,Rear blower
grantsmtih82
Re: DSP retrofit?
Post by grantsmtih82 » Fri Aug 23, 2013 8:18 pm
Is the wiring harness something that can be got from BMW ? Plug n play?
Does it involve removing loads if trim and running cable throughout
The car?  Also other than the harness is it just the dsp amp I need
Or is their subwoofers etc that go with it?
X MAN
Re: DSP retrofit?
Post by X MAN » Sat Aug 24, 2013 2:26 am
The audio and nav wiring harness can possibly be had from BMW parts dept but i guess
it will not come cheap, got mine from a breakers yard and is 100% plug and play.
The wiring harness runs from the rear (cargo area) along the n/s of the car and to each A and B pillars for speaker connections along and up from the centre console to the head unit, yes i guess a whole lot of trim will need to be removed for this retrofit.
You will need
1) Audio and nav wiring harness with DSP and subwoofer connections
2) DSP amplifier
3) Subwoofer x1  (rear O/S  cargo area)
4) 10 x 8ohm speakers/tweeters.
5) Rear door cards will need the holes cut out for the rear mids (already marked out at the rear)
6) Fixings for amplifier and subwoofer
7) Time and patience
My non DSP setup currently has 2 x 8ohm dash tweeters and 4 x 4ohm door speakers.
I dont think programming will be required but will cross that bridge once complete .
05 X5 3.0d
grantsmtih82
Re: DSP retrofit?
Post by grantsmtih82 » Sat Aug 24, 2013 3:09 pm
oh wow  thats a really big job.. i did notice some E53 had a subwoofer unit in the opposite cargo holder to the nav unit (just under the fuses)  i bet with the sub active it transforms the sounds audio inside the car...
how many speakers should be on the rear door  card?  i think i have 10 speakers
2 front dash  (one each side)
2 tweeters near the side mirrors (one each side)
2 on drivers/passenger door (one on each door)
the rear door cars have 2 speakers on each
so dsp systems have 12 speakers?
where about are you based XMAN?  where did you source your harness from?
Re: DSP retrofit?
Post by X5Sport » Sat Aug 24, 2013 3:34 pm
DSP have 12.  2 are the subs in the boot so you have the right number of door speakers.
Raj
Re: DSP retrofit?
Post by Raj » Sat Aug 24, 2013 11:48 pm
I'd personally go aftermarket. A lot of work for DSP but I'd just add an aftermarket amp/sub to your existing system.
grantsmtih82
Re: DSP retrofit?
Post by grantsmtih82 » Sun Aug 25, 2013 12:53 am
Raj. True aftermarket would prob sound better but would like to keep it all oem.  Just need to find wiring harness
Is there a quick way to tell if my harness is 100% not wired for it.  Quick way to tell?
Also did all dsp come with the subs or were subs yet another option?
dpbayly
Re: DSP retrofit?
Post by dpbayly » Sun Aug 25, 2013 9:51 am
If you are going down this route I have the dsp sub you can have
grantsmtih82
Re: DSP retrofit?
Post by grantsmtih82 » Sun Aug 25, 2013 7:44 pm
hi dpbayly
was the sub part of the dsp  or another extra?  what connector is used on the sub?  i assume its part of the dsp wiring harness??
how come you dont use it anymore?
dpbayly
Re: DSP retrofit?
Post by dpbayly » Sun Aug 25, 2013 8:25 pm
hi dpbayly
Yep part of the stock dsp system and it has an 8 or 9 pin connector that comes from the dsp amp.
I have it spare because I removed it when I beefed it up the bass, here's my post,
http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=2
grantsmtih82
Re: DSP retrofit?
Post by grantsmtih82 » Mon Aug 26, 2013 12:01 am
where in the uk are  you based?
i guess i still need to find a dsp wiring harness as mine wont came pre wired for dsp
Raj
Re: DSP retrofit?
Post by Raj » Mon Aug 26, 2013 12:26 am
As you need the amp and wiring I'd personally go with a box in the OE DSP location and hidden aftermarket amp. Just my opinion.
dpbayly
Re: DSP retrofit?
Post by dpbayly » Mon Aug 26, 2013 9:28 am
Little village called litlington not far from Cambridge
grantsmtih82
Re: DSP retrofit?
Post by grantsmtih82 » Mon Aug 26, 2013 9:40 am
my parents are in biggleswade, bedfordshire so not too far.
