Panoramic roof.?
Nine468
Panoramic roof.?
Post by Nine468 » Sat Aug 17, 2013 1:30 pm
Hi .
This is my first post on here.
Im looking at getting a E70 X5 soon, and im doing some homework on them.
I was originally looking for a E61 535d [touring] but cant find one to meet my exacting standards...
So the search turned to a E70..
Anyway...
The E61,s suffer from water ingress into the boot floor area from the drain tubes of the pano roof, causing the ecu,s that hide under there to get wet and damaged.....
My question is,,, do the E70,s have the same problems...
Thanks....
Dave W.
BMW G05 X5 40D
Pope
Re: Panoramic roof.?
Post by Pope » Sat Aug 17, 2013 1:39 pm
Absolutely NO problems with my 09 E70 Pano roof... :ok:
Oh, and welcome to the Forum..
:pope:
Garage:
BMW X6 40d Pink
Ducati Diavel 1198 Carbon
535dboy
Post by 535dboy » Sat Aug 17, 2013 5:00 pm
Having owned both cars I'd keep the search on for the 535, it is a much better car.
I had sunroof on both and had no end of probs with the E70 one.
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
petert
Post by petert » Sat Aug 17, 2013 5:58 pm
I've got the panoramic roof on my 2010 E70 - no problems after 3 and a half years.  I don't open the roof that often though - mainly it's for the better interior light.  The internal shade gets moved a lot, positioned to help reduce glare depending on position of sun re direction of travel.
Peter T
535dboy
Post by 535dboy » Sat Aug 17, 2013 7:10 pm
I also found the roof really noisy open even in so called comfort position on the E 70
No such problems with current car or 535
Currently :
2012 Audi RS4 (B8)
Previously :
Nine468
Post by Nine468 » Sun Aug 18, 2013 10:48 am
Thanks for the replies folks. :)
The main problem ive read about is the drain tubes that allow any water to drain away to the ground/outside the car, have a small filter gizmo in them , this over time gets blocked up and the water then flows nicely into the boot floor area, causing the ecu,s that are down there to get damaged.  :( :( All this can be unknown about until the electrical items stop working, costing ££££,$$$$$, to fix....
This ive only read about on the E61 5 series tourings with a pano roof.
Ive no idea if this happens on the E70,s that's why I asked the question....
Dave W.
BMW G05 X5 40D
Post by X5Sport » Sun Aug 18, 2013 10:59 am
The problem that the E53 suffered more from, and it may become the same in the E70, was mechanical failure of the rear section drives.  This could only be fixed by replacing the 'cassette'.  A number of owners disabled the rear section into a fixed position which solved the issue.
If the cassette design was moved across from the E53 to the E70 then the same problem may be waiting to bite owners as the cars age.
535dboy
Post by 535dboy » Sun Aug 18, 2013 12:25 pm
I ended up getting a new cassette after many fights with BMW.
Currently :
2012 Audi RS4 (B8)
Previously :
Nine468
Post by Nine468 » Sun Aug 18, 2013 10:38 pm
Any idea what caused the mechanical failure.?
Was it lack of lubrication.?
Dave W.
BMW G05 X5 40D
Post by X5Sport » Mon Aug 19, 2013 5:52 pm
Cheap plastic components breaking!
