The other half has told me we have the above message on the car, any clues?
	Tyre control Inactive
				Gurbinder
03 53 M3 CSL SG 10.5K
03 53 4.6IS BLK/BLK
12 12 Pathfinder 2.5 DCI Tekna
						03 53 4.6IS BLK/BLK
				phill
I currently have this, try checking the tyre pressures and then reset tyre pressure monitor system, this should get rid of the message. If the message appears again after a short drive 1 of your sensors in the wheels has failed and will need changing £65 + vat + fitting. You will need to take to either BMW or Indy and have them plug in the computer and that will tell them which one it is.
2003 X5 4.6is - Now dead
				Gurbinder
Re: Tyre control Inactive
Thanks another thing to add to the list!
03 53 4.6IS BLK/BLK
						03 53 4.6IS BLK/BLK
				Gurbinder
What do I press to re set tyre pressure monitor?
03 53 4.6IS BLK/BLK
						03 53 4.6IS BLK/BLK
				phill
Turn ignition key to position 2 and press RDC button until it says tyre pressure set about 10 seconds
Sent from my iPod touch using Tapatalk
