E70 Angel eyes issue?
paulrog
Post by paulrog » Sat Jul 20, 2013 4:39 pm
Hi, I have a 2007 E70 with Xenons, the previous owner had replaced the H7 36W with H7 36W lamps with a blue tint to them which produce a really good white DRL light.
But... the inner ring is a lot brighter than the outer ring on both sides!!, is there anything I can do about this?
Re: E70 Angel eyes issue?
Post by X5Sport » Sat Jul 20, 2013 7:11 pm
No.  The inner ring is the one with the best light output even on later models until the LED Versions appeared.  The light guides are from the inner lamp so it appears to be the brightest on all versions I have seen.  Apart from the position of the filament being moved, that's just the way these lamps work, even with OEM bulbs.
This is a 2011 model year X6 with HID look lamps......
