Brake disc help
Brake disc help
Hi everyone
Can anybody tell me what would cause the front disc pad to only grip 2/3 of the disc and is it a problem?
Brakes feel fine with no pulling or anything.
Tim
Sent from my GT-I9300 using Tapatalk 2
Tim
Re: Brake disc help
They could be the wrong pads ? If it has the same effect on both sides, if on one side only, if they are a two piston type caliper, maybe only one piston is working and the other is seized, Is it the same on both front discs?
Re: Brake disc help
Just on one side - front n/s.
Will give them a strip down ay the weekend and see whats going on.
Re: Brake disc help
Looks a bit weather beaten
Does the wind driven rain hit that side of the car , I have the same issues with a couple of cars if not used every day .
The pads will still grip on that surface as you can see in the pic but they will wear faster .
There trims available which fit on the inner rim . These will keep the weather out .
There is a UK supplier if you search
http://www.kleenwheels.com/kleen-wheels-dust-shields
Re: Brake disc help
Check the top Allen key bolt is in place and tight too.
Re: Brake disc help
Will do - thanks Sanj
Re: Brake disc help
From the picture and the reflection across the whole usable diameter of the disc your pads ARE biting on the whole disc- now!
My guess is that the previous set of pads were jammed in the caliper- thus not fully making contact with the disc. New pads installed but disc not skimmed/ replaced. The pitting in the photo is below the level of the top surface of the disc.
It will eventually (after many thousands of miles) wear the disc down to an even level. Of course braking force on this side will not be as high as the opposite side- but barely noticeable.
I would measure the thickness of the disc and if within the limits have it skimmed.
Let us know how you get along.
HTH
HTH
E70 3.0D SE, Black with Black - Gone but not forgotten! >:D
Re: Brake disc help
Hi HTH
Thats good to know - very many thanks for your advice.
Will post how i get on
Tim
Tim
Re: Brake disc help
No problem.
HTH = hope this helps! )
Re: Brake disc help
Lol - thought HTH was a bit odd as a name! :-
