Hoping someone can help me as I'm travelling on holiday in the Uk at the moment. Last night I packed the car up and put cycle rack and two bikes on the rear mounted rack. When I pressed the button to lock the car the audible beep didn't sound. I figured something wasn't shut properly but couldn't identify what. The little red light beneath the rear view mirror came indicating alarm was activated(?). I was apprehensive that I might have come out to a drained battery this morning but all seemed fine. I cant see if the boot light comes on as the car is full of luggage.
As soon as I set off I got a bootlid open error. As I'm only partway to my destination (700 miles ish - yes in the UK), there isn't a huge amount I can do til I get there. I cant physically open the boot as the weight of thee bikes on the rack prevents that (when i hit the unlock boot button it shuts again immediately due to the weight. IT seems completely shut yet it is recording a boot open error. Could the clasps that go on the edge of the tailgate be prising it open enough to record a bootlid open error but without triggering the interior light to drain the battery. tucked up in ab and b tonight fingers crossed that I don't drain the battery overnight.
Any suggestions?
bootlid open error
Re: bootlid open error
the issue has gone away all by itself
I had this problem on mine. It turned out to be one of the microswitches in the locking motor and I had to replace the motor. Hopefully yours won't happen again but in my case, it did.
BMW X5 3.0d M-Sport facelift (E53).
Mine is the same. If you dont close it firmly it will report the boot is open. I would check the bump stops for the boot lid, I believe they have been upgraded to solve this small issue.
2002 4.4 cooking on gas
