Need a favour
I need to measure my battery bay but I can't get to it as there is a full up LPG tank on top of it at moment and weighs an absolute ton.
I need to know the maximum length I could fit in there.
At the moment I have the Bosch S5 and my local battery shop tells me its:
Length (mm) - 353
Width (mm) - 175
Total Height (mm) - 190
The Varta battery I want to order is:
Length (mm) - 393
Width (mm) - 175
So only slightly longer and I remember I have a slight bit of room in the Length but I don't think I could use the battery bracket to screw it in as it would go past that whole for the 10mm screw pole thingy but the LPG tank should stop it from moving anyway.
The battery shop won't order it until I can confirm it will fit as they can't send it back if its too big.
So if someone would be so kind get me the measurements I would really appreciate it
Thanks!
James
