coding
Mpower
Re: coding
Post by Mpower » Sun Jun 09, 2013 10:18 pm
Thats right Richard MS have gotten into bed with BMW regards to the OS of their media interface in future models.
Good news that you are a step closer on the coding ladder and thats what this forum is all about helping and sharing!
Re: coding
Post by X5Sport » Mon Jun 10, 2013 7:16 pm
Well I think I've got the VM up and running with the BMW Toolset, albeit with some of the instructions not actually working in the order listed - but I got around it.
The next trick is to find the right 'Daten' files that cover the E71 for MY2011.  Once that little gem is sorted and found them I can make more sense of what the manuals say and can start to interrogate the car.....and try the E46 too.  I don't expect SWMBO will let me within 10 feet of her Mini...... :P  :guns:
Nothing seems to be a 5 minute job though.  Just patching the Virtual PC in XP mode took 2-days!  Anyone thinking of going down that route needs to probably put one weekend aside just for that part - there are over 200 patches that need adding as the XP snapshot is several years old - 2006 I think - and SP3 must be added under an Admin function before the rest of the patching works as MS no longer 'recognise' XP SP2 for updating.  At a guess I would say the VM and patching is over 1.5GB in downloads.
simpic
Re: coding
Post by simpic » Mon Jun 10, 2013 7:20 pm
Richard,
Is it possible to create an ISO of that VM image and upload it to usenet?
Regards,
Simpic
Mpower
Re: coding
Post by Mpower » Mon Jun 10, 2013 8:42 pm
Regards to daten files for your E71 use the ones for the E70 basically they share the same modules.
Richard,I know its a bit late for this now but I would of partitioned the harddrive and installed XP or Windows 7 to that partition and install the NCSExpert to it!
Have you received your cable yet?
Mpower.
Re: coding
Post by X5Sport » Mon Jun 10, 2013 10:01 pm
Not ordered yet, but the VM of XP runs in it's own VHD and is separate from the main system.  The system takes a snapshot every time the system it's shut down and saves it's 'state'.  I can move it to a completely different drive if I need to.  I've got 1TB to play with and a spare 3TB drive if necessary.  I think the VHD is 25GB at present but can be resized - and there's lots of room.  I can 'capture' various ports to use them as needed - like USB.
Right, off to find the Daten files from 44-47.........
Bomber
Re: coding
Post by Bomber » Tue Jun 11, 2013 11:39 pm
I have v49 if you have no luck let me know and I'll see if I can host them somewhere for you to download
Caesium
Re: coding
Post by Caesium » Wed Jun 19, 2013 3:06 pm
MPower, I'm also in Herts.
Don't fancy doing some coding do you?
I've also got VDCS, an original ross-tech one. Shame I no longer have a VAG car.
Currently :
2013 BMW E70 X5 40D MSport
Previously :
2008 BMW E92 335D MSport
2004 BMW E46 M3
2005 BMW E60 535D MSport
2002 BMW E39 530D Sport
The list goes on...
Mpower
Re: coding
Post by Mpower » Wed Jul 03, 2013 12:18 am
Won't be doing much atm 'cos the laptop has died on me.
Hopeful that I can rescue the data on there!
Caesium
Re: coding
Post by Caesium » Mon Aug 12, 2013 2:27 pm
I bought my own lead in the end and coded mine to shut and open the boot on the key and from the button inside, also to fold the mirrors on the key. Easy Peasy!
Currently :
Previously :
2004 BMW E46 M3
The list goes on...
Mpower
Re: coding
Post by Mpower » Wed Nov 13, 2013 6:58 pm
Good for you!
markda
Re: coding
Post by markda » Fri Nov 15, 2013 6:55 pm
I'd love my mirrors to automatically fold/unfold upon locking/unlocking.  What is the reason BMW won't add this functionality?
Mpower
coding
Post by Mpower » Fri Nov 15, 2013 7:24 pm
If you have the folding mirrors its just a case of coding them to work by remote/CA.
markda
Re: coding
Post by markda » Fri Nov 15, 2013 8:40 pm
Fantastic, how?  Regardless of how technical I used to be.  I don't fancy tinkering with any laptops and cables near my car - what are my options?
Mpower
Re: coding
Post by Mpower » Fri Nov 15, 2013 8:52 pm
Firstly I would get yourself a cable so you can code your car to your hearts content but as you 've just posted that you are not going to do that where are you,PM if you want?
markda
Re: coding
Post by markda » Sat Nov 16, 2013 12:26 am
Nr Basingstoke, Hampshire.  How much are cables and the software?
