They arrived yesterday but unfortunately after a quick bench test I found one of the smaller rings was not working so gave the chap a call and arranged for a replacement and while I was at it as they were only £22 I ordered a second full set just so I had spares in case I ever need anything.
Well the other ring didn't turn up today and I couldn't wait to start fitting them up so decided to do the one, fingers crossed the replacement will come tomorrow....
Split the lights with a little mini hot air gun I was surprised how easy they are to split, once split I went ahead and fitted the rings and while I was at it I gave the lenses a good clean:
Here they are back together through the tinted lens:
Switched on:
Fitted back to the car not on you can just make out the rings:
Side lights switched on:
Cant wait to get the other one sorted.....
