Re: X5M vs diesel discussion
snipez999
Re: Re: X5M vs diesel discussion
Post by snipez999 » Thu Apr 25, 2013 11:07 pm
Shame it's for bum boys at the end of the day though
ROFLMAO
Current: Bentley Continental GTC V8S
Previous: Aston Martin DB9; X6 M50d; X6 40d; 535d M Sport; 330d M Sport
Chompers
Post by Chompers » Fri Apr 26, 2013 1:06 am
[quote="snipez999"]
ROFLMAO
I asked for this Petrol v Diesel chat to be split from the original X5M thread because I thought it held interest for quite a few people with very different points of view. So lets not let this one decend into  :bangin: each other :ok:
Current
Previous
535dboy
Post by 535dboy » Fri Apr 26, 2013 6:48 am
[quote="Chompers"]
[quote="snipez999"]
ROFLMAO
It's ok he is just jealous he doesn't have an imagination and keeps buying the same or similar cars!
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
MaXX99
Post by MaXX99 » Fri Apr 26, 2013 7:12 am
In my opion it all depends on the vehicle you are in ...
Our E70's are large, heavy chunks of metal with big wheels to fit ...
It is by no means a sportive car or has sportive handling, no matter which trim we are talking about (I drive a 40d with adaptive sustpension & steering). Although it can corner a bit better than most other SUV's, in the end it is still an SUV which is at its best on the highway or for straight line accelerations.
Personally I prefer the power distribution of the diesel engine in these types of vehicles, with low end with loads of torque. Or if price and taxes were no issue, a HEMI 5.7 engine which shares these same characteristics.
Performance Petrol engines with a ton of HP like in the M series sure are fun, but don't suit the car as well in my opinion ... But in a vehicle with a much lower point of gravity ans suspension to match ... sure  :mario:
Raj
Post by Raj » Fri Apr 26, 2013 7:52 am
Hmmm, I've owned both a tuned E60 530d and E60 M5 which is quite a good comparison as both engines were contained in the same (in essence) vehicle. The diesel is a stonker and as has been stated they have come on in leaps and bounds from tractors of old. The diesel provides great performance an abundance of torque and with the right mods (mines was on upgraded suspension, ARB's, big brakes, etc, etc) and although it shocked a few round The Ring it just couldn't keep the power/torque when you needed it. A manual gearbox may of helped but it kind of defeats the proper marriage between a decent Diesel engine and an auto box.
Also although the sound deadening is superb for the cabin outside you still know its a diesel as no leaps in technology have been able to address that.
I understand the TT of even newer models helps but there is also the issue that unless you are Eli the mileage it's actually no cheaper to run.
Moving to the M5, the torque was on par with the diesel although its obviously a massively enlarged capacity to achieve it over the equivalent torqued diesel but it pulled far better, was more exciting/fun, handled better even from stock, grabbed more attention and generally was just around MORE.
OH and I forgot to mention the SOUND. Seriously To Die For.
As I mentioned in the other thread re the RS models, they are just an alround better package and hence why they are better depending on your circumstance and usage.
If someone were to offer me either the X5M or 50d for example I'd be in a real tis over which one to choose but it wouldn't be down to the factor one was a petrol and the other a diesel it would be down to many other factors we have to take into consideration.
However if the diesel were just a 30d then no contest as the M will always come out on top.
Post by X5Sport » Fri Apr 26, 2013 10:34 am
The main thing I miss about these big diesels is not being able to get one with a manual transmission.  That way the driver really has so much more control and can make sure that the engine is running at optimum rpm for any manoeuvring/pressing on without having to wait those extra fractions of a second whilst the torque converter and related electronics thinks about the request from my right foot.  Our E46 with the 30d engine and a manual box is great for that because there is no delay, and if you time it right then the turbo is also spun up to higher rpm so providing the extra oomph much earlier.  Turbo lag is less of an issue now I know (and that's true of the twin and triple set-ups in the X5/6).  If I put my foot down in the right gear it's away!!  OK being rear wheel drive helps too - except in dodgy weather when it's a little to keen to swap ends - but that manual box to me makes a big difference to the enjoyment that even a current 8-speed box cannot match.  You can't easily 'block change' with a steptronic auto the way you can in a manual either.  I know the 8-sp can shift from M8 to M2 in one shift, but........it still needs lots of pulling on the paddles whereas a manual you just move the lever once!!
Chompers
Post by Chompers » Fri Apr 26, 2013 10:48 am
e46 330cd vert was a rare car in 30d terms, never came with a auto option. Clearly manual is the prefered option for pressing on through corners, having just come back from another blast in the 125d and using all auto box options it was still found wanting. The biggest area of issue was corner entry no matter which set up I used I struggled to set the car up for a progressive exit. However once out of the corner the thing was gone  :o there is no doubting these twin/triple engings a amazing and I would suggest the 8 speed A is the only way to go in non 'X' models.
[quote="MaXX99"]
well said that man  :)
Current
Previous
Post by X5Sport » Fri Apr 26, 2013 11:49 am
[quote="Chompers"]
It couldn't pass the Euro4 emissions with an Auto, hence manual only.  And we're hanging onto ours!!  It's too much fun to drive.. :drive:
Reminds me I need to service it now it's in 'storage'.
R
Lee4.8is
Post by Lee4.8is » Fri Apr 26, 2013 12:02 pm
I do think its personal preference some like the low end shove & awesome overtaking ability of a diesel while others enjoy revving an engine out & getting the rewards for it, I wouldn't say no to a drive of either the 50d or X5M  8)
Current...E90 330i M Spt Blue/Black  2006
              640d M Spt Blue/White 2012
Previous...
Audi TTS Black 2012
E53 X5 4.8iS  Blue 2004
               E92 M3 White 2009
               E85 Z4 MR 2006
               E61 520d  2009
               E90 330d  2006
               TVR Cerbera 4.5 1998
Chompers
Post by Chompers » Fri Apr 26, 2013 12:27 pm
[quote="Chompers"]
R
I understood it to be a kerd weight issue, also interesting that there isn't a 35d e93. Surely that engine/auto box set up was used in loads of guises around 2005?
As for getting your vert out, best hurry up, summer is almost over  ::) has been nice to be back in a vert, iIhave to say  8)
Current
Previous
snipez999
Post by snipez999 » Fri Apr 26, 2013 12:28 pm
I'm addicted to the X6 though - can I get help somewhere?!
Sent from my iPhone 5 using Tapatalk 2
Chompers
Post by Chompers » Fri Apr 26, 2013 12:28 pm
[quote="Lee4.8is"]
Indeed, only to go and then put a deposit on an F10 M5  >:D
Current
Previous
Chompers
Post by Chompers » Fri Apr 26, 2013 12:31 pm
[quote="snipez999"]
Sadly I think this is the best place for you  ::) anybody you spoke to about this issue in the real world would call for the men in white coats to come and pick you up!!! :sos:  ;)
Current
Previous
Lee4.8is
Post by Lee4.8is » Fri Apr 26, 2013 2:15 pm
[quote="Chompers"]
[quote="Lee4.8is"]
Now we are talking!!!  8)
Previous...
Audi TTS Black 2012
               E92 M3 White 2009
               E85 Z4 MR 2006
               E61 520d  2009
               E90 330d  2006
Post by X5Sport » Fri Apr 26, 2013 2:30 pm
Chompers, I was surprised too that there was no Auto for the 330CD MSport vert, and it was the dealer who said it was an emissions problem as the model went into production after the cut-off for meeting EU4.  I think there was an auto in the other versions of the 330CD like the coupé and saloon (?) so the extra weight of the structural supports in the 'vert' may have tipped it too far
Ours is SORN'd and needs 'bringing back to operational life' ie money spending on buying the tools etc to service it, MoT and insurance....so it's going nowhere.  The arrival of our little one has rather pushed the dates back a wee bit.... :(
R
