Well this car officially takes the p!ss now
Part arrived this morning....handy guides in hand I made a start
(thanks for the links)
Struggled with the wing/bumper attachment and may have broke one of the clips....damn
Easy to see how it works when it's off...not so when it's one. Two slots about 10mm wide that you cant see in the bottom bumper...that fingers ( as part of a moulding) hook upwards into. Yes you must poke something in to the holes to shove the fingers down but it aint easy when trying not to damage the wing.....result....snapped 1 of the fingers.
ANYHOW
Before I tried to replace I made sure the vehicle was away from objects in anticipation that when replaced but not bolted up I could test the success when the bumper was just hung back on
Other half wafts arm in front and sure enough the centres and nearside corner worked. NOT a peep out of the offside corner...must have been completely dead
Off with the bumper and eventually (fog light cables restricting movement) get corner one out. Now loose I figure out how the cable comes off (handy having the new one) as its covered in grubby dust.
New one fits perfect...3 pins and all.....hoooooorah...£20 might not be wasted
Pushes it into hole and hangs bumper loosely back in position.
Test..................BRILLIANT......beeps as it should do. Intermitant to solid......coffee as a reward for crawling about.
Takes out on road.....ok....parks up.
2 hrs later....gets in....puts it into reverse BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEP SOLID TONE.....FFFFFFFS
Wouldn't clear till I either pressed button or drove off.
Pulls into chippy laybye on way home. Presses button....no tone as one would expect with nowt near....did go off when someone walked past. Started engine.....drove home onto drive.....tempted by the button BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEP SOLID TONE
Damn
Just been out and all are clicking....and the offside one I replaced click nice and loud now (the old one was faint) and it works ok
WTF is going on with this intermittent fault......Is it the control BOX in the boot, a wiring fault....WITS end
